FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
post-14998384
Post #2,446 of 8,320
Caguioa
Your shure 846 CANNOT LDAC, JUST SBC! It's the same worst BT codec! Just the RMCE-BT2 supports the better codecs.
The problem is not to find @mobile device M11, just in the amp of your BT headset! This is the reason, why you cannot hear a difference between low gain and high gain (via control @M11 device) while listening via BT AND this is the reason of BETTER battery life if you just using BT instead the internal M11 app!
Pls. Inform you about the different BT codecs, about internal M11 amp and external BT amp (in your headset for example) otherwise you will use / handle your hardware wrong in every case.
used SBC on my shure on m11, soun sounded low volume at max 120 volume.
post-14998414
Post #2,447 of 8,320
Sven2015
Remember. I use LDAC via Sony headphones X100M3 WITH music app in comb. limiter, pre-gain -4 dB AND replaygain 89 dB and it's loud enough!
post-14998430
Post #2,448 of 8,320
Leetransform25
America
America
did u read the rest of my post ?
then what are some headphones?
I tried switching to SBC for my beats and it sounded the same even at 120 volume
I have the Shure 846's and at 120 volume + LDAC,APTX,SBC and....
it STILL sounded LOW just like the beats, i was told
RMCE-BT2 is better, and i will be getting those soon. IF it still plays the same..then it must BE my M11
It seems that the M11 generally has an issue with low volume through Bluetooth, so it could just be your M11. Can't say for sure though
post-14998451
Post #2,449 of 8,320
bumbum
Vienna
Vienna
So, I've been enjoying the M11 during the day and it sounds wonderful out of the box. Have only been testing FiiO Music with default settings. Balanced. High gain. Also a little Spotify.
I've been wondering because I was a little worried but now I'm not.
First off, the WiFi is completely alright. I've downloaded about 10gb of music via Spotify and has been really fast. As fast as my cellphone (flagship Xiaomi / 5gh). Since I'm using both SD slots for my personal HQ library I've selected the internal storage to store Spotify offline files. So, for those complaining, can it be due to you guys downloading straight to SD / slow cards?
My second concern was the heating / player getting hot. So far I haven't felt the player getting hot? This afternoon I've been playing flacs for two hours. I think my phone is even warmer now as I type (it's not, it's cold). I'm playing this (Balanced output, High gain, FiiO Music) and it's still pretty cold. 24bits / 192kHz / 4840kbps. DAP sitting over a wooden table / this afternoon sitting on my belly. I'm on the latest firmware.
I've got mine today. I'm running cca 5 hours now. No heat and it' sounds amazing
Reactions: hldn
post-14998453
Post #2,450 of 8,320
BadReligionPunk
Saint Louis
Saint Louis
post-14998461
Post #2,451 of 8,320
bumbum
Vienna
Vienna
Didn’t mean to come across sounding so aggressive, apologies. I’m sure you’re hearing what you’re hearing, and my mild hearing loss is at work preventing me from picking up any hiss from this device. Lucky me! Many years as a teenager blasting tapes into my eardrums has had the (un)lucky effect of making me super sensitive to tape hiss and not really being able to pick it up at the same time :head_bandage:
I have the same combo. M11+fh5. No hiss at all by pause skip. I've noticed by some songs with lower sq
post-14998484
Post #2,452 of 8,320
lesale08
A place of corrupted and greedy people.
I have to believe so. Even my SBC phones are loud as can be.
I only have tried using the bt on a bt speaker that I got free from my cellphone purchase and they sound very loud. I will check and try with my car sterio to see if there is a noticeable volume difference from my phone and other dap.
post-14998511
Post #2,453 of 8,320
Caguioa
DOESNT matter dude, the fact i am USING SBC with my bluetooth device thats SBC
and AT MAX VOLUME AT 120 it SHOULD BE REALLY LOUD,
again ITS SBC AND I AM ABLE TO PLAY IT AT 120 VOLUME AND VOLUME IS LOW.
WHEN I GO 120 VOLUME VIA WIRED MY EARS ARE ABOUT TO EXPLODE
post-14998526
Post #2,454 of 8,320
FOBean
Washington, PA
Washington, PA
Ordered from Amazon on 29th, expected next Wednesday and it decided to show up today! So far, it feels and sounds good straight out of the box! Much better than my iPhone 6s, as expected, which I compromised for so long as my mobile/sleeping device. Get's my IEMs much closer to my desktop rig. Awesome device!
Thanks for the info and picture!!!
BTW, what are the black IEM's above the Andromedas? I've been wanting to add another pair of TOTL IEM's to my current CA Andromeda and Dorado IEM collection, and I'm having an IMPOSSIBLE time deciding on something new with the IEM market being SOOOOOOOO flooded right now!
TIA :wink:
P.S.- I've had my Shanling Audio M5s DAP since the first batch was released in December, and it sounds AMAZING IMO. Same Dual AKM 4493EQ DAC chips and similar components and features, and is almost the exact same price! I can't stress ENOUGH how good the new Shanling Audio products are, and their customer service is TOP NOTCH and second to none, since they're a rather SMALL company who REALLY values and cares about their customers! I HIGHLY recommend the M5s DAP, and I'd LOVE TO read a few reviews comparing the M5s to the new FiiO M11 :)
post-14998531
Post #2,456 of 8,320
Leetransform25
America
America
Read your signature and noticed you have a Z7. What are your opinions on it, and how does it pair up with the M11?
post-14998541
Post #2,457 of 8,320
abitdeef
Formerly known as ihatepopupads
TIA :wink:
I had M5s and as I mentioned earlier, the shanling is warmer sounding and the stage is bigger on m11. Honestly the m5s sound didn't compare to my sr15/,zx300 in the fact that the treble was too soft. It sounded nice, it just didn't do it for me.
The m11 wowed me immediately, probably because I like a more neutral detailed treble sound. So in a nutshell, me I personally liked the m11's sound better.
post-14998562
Post #2,458 of 8,320
fatmanny
Regina, SK
Regina, SK
TIA :wink:
Looks like the Oriolus MkII to me
post-14998586
Post #2,459 of 8,320
Ryokan
South East
South East
I keep reading this is a neutral player (I read that as boring) which almost put me off, but this is a step up from what I'm used to.
post-14998601
Post #2,460 of 8,320
Ojisan
Texas
Texas
TIA :wink:
Thanks! The one in the picture is Oriolus Mk2 Japanese edition. IMHO, it’s an excellent hybrid that has good dynamic bass, sweet mids, and good treble. The tuning of the mids are different from Andros. I prefer rock/jazz on Oriolus, classical on Andro. My other hybrid IEM is Hyla CE-5 which is supposed to be iBasso’s tuning reference IEM. This is more V-shaped with excellent bass and treble. These are probably side-grade from Andro with different flavor but priced right if you can find it used. Still cheaper than so-called top IEMs, even when combined with M11 :) Good luck finding your fav!
Reactions: dilpal and Vitandus
Users Who Are Viewing This Thread (Users: 15, Guests: 15)
