gazzington
Also a bargainAgreed.. or this and some r6 rui
Ya I got a copper 4.4mm off AliExpress. It's been unreal so far. My only complaint is it's a little too short, but that's my fault for not checking length
Or maybe we're just talking about different things?i guess it depends what you call dead silent. I’m probably too deaf to notice
Ok then I can only repeat from my experience and my ears - when there’s no music playing or a track is paused there is zero hiss. None. Balanced, high volume. None. So either you’re super sensitive or I’m stone deafOr maybe we're just talking about different things?
I'm talking about hiss evident when no music is playing or when it is paused.
I can't hear any hiss during playback. If that was the case I would have already returned it in a blink of an eye - not only M11 actually but anything that would supposedly be a high end music player.
To my experience the only player I have had that was as silent as you describe was DX90. It didn't make any difference whether you had the earphones connected or not - dead silence.Ok then I can only repeat from my experience and my ears - when there’s no music playing or a track is paused there is zero hiss. None. Balanced, high volume. None. So either you’re super sensitive or I’m stone deaf
What can I say, hearing loss has its benefitsTo my experience the only player I have had that was as silent as you describe was DX90. It didn't make any difference whether you had the earphones connected or not - dead silence.
To get enough power output , the gain is a little high and the hiss from balanced is a little higher than 3.5 single end. it is normal .
