[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Apr 6, 2019 at 6:56 AM Post #185 of 9,308
How does it compare with X7II with AMP3B??
Apr 6, 2019 at 7:21 AM Post #186 of 9,308
Oh ok here you go 100331811518880
Much appreciated
yes, I found your order and should be shipped tomorrow cause we need to update the firmware first.
Apr 6, 2019 at 7:46 AM Post #187 of 9,308
M11 is not the same class in SQ compare with X7II, there will have a new model to replace the X7II after couple months.
Apr 6, 2019 at 7:55 AM Post #189 of 9,308
Maybe, but we will have someone to arrange the shipment in couple hours but not sure whether all the package can be delivery in time.
Oh ok. Here is my order number if it helps.
100500980094049
Apr 6, 2019 at 7:58 AM Post #190 of 9,308
Apr 6, 2019 at 8:06 AM Post #191 of 9,308
Understood, but bet there are many new or newer daps you never tried before already in the market.
  • This one at least as good SQ of X5III from what I read. Had one & liked the sound but some issues & lag.
  • This one has 2.5 & 4.4mm balanced (important for me)
  • Looks stunning (as does the X5iii)
  • Screen fills the front (don't like tiny screens on big daps as per Sony's)
  • Will take my 2 x 512GB mSD cards.
  • LDAC to work with my BTR3 + SE846's
  • Reasonable priced.
  • Long standby time and playback time fvia LDAC BT looks huge!
Oh...…… I want to treat myself to something new and why buy older tech.
Apr 6, 2019 at 8:19 AM Post #192 of 9,308
The current Tidal app should support MQA on any Android device. Or use UAPP but not sure if it's possible to install the app since the M11 (and probably the next Fiio's high-end DAPs) doesn't suposup Google Play store.
I have UAPP apk as I normally try some beta's for them just before official release. Will be trying when my M11 arrives from Alli, plus I do have the UAPP MQA license too.
Apr 6, 2019 at 8:23 AM Post #193 of 9,308
I know any android device supports MQA but without the MQA certification it won't perform the final unfold to the full 24/192. Also as far as no google play store, I have seen some mentioning aurora store as an alternative and saying it works nicely going to give that a shot when I get mine. I haven't seen anything official about google play support but there have been things said about the M11 launching in china first because it is easier since they don't need google play support as much over there (not sure if it is actually true), so that kind makes me interpret that as there may be google play support in a future firmware for the US version once launched. But I could be interpreting that wrong.
I have an LG V30 which has MQA hardware decode and listening at 24/96 vs 24/192 I'd say its really not noticeable, but I do only use Shure SE846's these days.
Apr 6, 2019 at 8:28 AM Post #194 of 9,308
September/October? Does it have amp modules lile the announced AM3D?
