One question I have for more experienced users, how do you traditionally manage playlists on FiiO devices? I don’t usually listen by artist or album but have many playlists I’ve built in iTunes over the years. Is there any way to do so this on a computer or do have to do it in the device?
Hi, i have the M6 and X7ii. I have interest in the M11, but only if it has the ability to run 3rd party apps generally, like the X7ii. My main problem wit the M6 over the X5iii/X7ii is the lack of choice in music player. The FIIO stock player is not ideal (global search is maybe 25% effective), and there are a host of good player choices out there which I use concurrently on my X7ii (UAPP, Blackplayer, Gone Mad, etc), and for different reasons.
So... will/does the M11 have limitations like M6 and M9 with 3rd party apps? Also which version of the Fiio app will be installed? The more basic one on the M6/M9 or the better one used on the X7ii?
Also will the M11 support Chromecast streaming (less of a deal breaker )?
If these key features are absent then I am deifnitely passing.
