Yes of course it does, just not AAC BT unfortunately.Anyone know it this DAP supports AAC files?
[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
dsrk
That new dynamic EQ (on the latest firmware on X7II) is not dropping the volume but sadly it is resulting in distortion. On bass heavy songs, even 2db is resulting in distortion and it's not acceptable. Happiness lived only for a day, the hunt for better EQ continues. Seems like my next DAP upgrade will only be a COWON.
jmills8
Previously known as bmiamihk, jmills2
If you want a clean eq, yeah Cowon and Cayin. Colorfly has two kinds of eq in their U8 dao.That new dynamic EQ (on the latest firmware on X7II) is not dropping the volume but sadly it is resulting in distortion. On bass heavy songs, even 2db is resulting in distortion and it's not acceptable. Happiness lived only for a day, the hunt for better EQ continues. Seems like my next DAP upgrade will only be a COWON.
dsrk
Don't know about N8 but has N5II for a while it's EQ was worse than the FiiO's. I have been using Cowon DAPs for more than a decade and still love them for their excellent EQ. Plenue L is definitely going to be my next DAP unless Cowon release an Android based DAP.If you want a clean eq, yeah Cowon and Cayin. Colorfly has two kinds of eq in their U8 dao.
jmills8
I jave the N8 , PL and various Fiios. N8s eq is nice.Don't know about N8 but has N5II for a while it's EQ was worse than the FiiO's. I have been using Cowon DAPs for more than a decade and still love them for their excellent EQ. Plenue L is definitely going to be my next DAP unless Cowon release an Android based DAP.
Is this a software problem? Is there a chance to make it drop the volume, or helps to do it manually? I'm a little bit confused, shouldn't the other DAPs produce the same problem?
dsrk
It could be a bad implementation, most of the present DAPs face the same problem and don't have clue why. Apps like Neutron has the gain slider to get rid of that distortion problem but that too feels subpar. The best EQ implementations so far are Lotoo and Cowon. Hiby MESB is great but EQ is not great.Is this a software problem? Is there a chance to make it drop the volume, or helps to do it manually? I'm a little bit confused, shouldn't the other DAPs produce the same problem?
nigel801
- Apr 23, 2009
Hi James,yes,
Your privacy settings restricted for personal messages hence contacting you here, I live in Netherland and saw M11 was available for shipping on Ali Express so I ordered it but not sure if this can be shipped because on the event day it was mentioned in Europe it will be available end of May 2019.
My order number is
900101010498412
Thanks for your support.
Hi James,
My order number is
900101010498412
Just checked with our colleague , they told me that all the M11's order had been deliveried to our forwarder but they just start working yesterday so we are still waiting the tracking number from them and them we can change the status on Aliexpress.
crazyeyes
- Feb 7, 2005
That's great news. Looking forward to getting mine.
loungecat
My Unit has finally shipped ,delivery is looking like Thursday so far. Super Pumped
crazyeyes
- Feb 7, 2005
I got a shipment notification but no eta it just says shipment info received.
fatmanny
Is there any difference between the Ali version and the NA version?
I asked the same twice mentioning @JamesFiiO , "Is the hardware 100% exactly the same or there's possibility of small chances?", got no answers. I guess silence means consent, i.e., they are in fact early units and there will be different parts?
Not sure about what NA version means, but there are not any change in the hardware design by now. and there are only one version.
