YUHaveNoNames
- Mar 17, 2016
Hi FiiO, what's the deal with the headphone stand that I've read about several times now, that it was with some people? Best regards
![20230331_152403.jpg 20230331_152403.jpg](https://cdn.head-fi.org/a/12027460.jpg)
This is what they came with.
Dear friend,Hi FiiO, what's the deal with the headphone stand that I've read about several times now, that it was with some people? Best regards
Hello!Dear friend,
* For the first batch, each FT3 order can get a support stand as a gift. First come, first served!
Best regards
Dear friend,Hello!
What batch of headphones is now on sale, the first?
I bought fio ft3 from aliexpress yesterday. Will I get such a stand?
https://fiio-shop.de/Fiio, is there any store in EU where FT3 could be purchased from, so I dont get import duties?
Thanks.
Keep us posted, well written, fair play!I just received mine first thing this morning so these are my initial impressions a couple of hours in.
First things first….. The headphones arrived triple boxed. The box and accompanying accessories are top notch. The initial impression when looking at everything is that this is a $500 headphone at least. The included case is very well designed and comes in its own felt bag. Nice touch! The case contains a built-in compartment for the cable and a Velcro attached holder for the cable accessories. All of it is well thought out.
The cable itself is wonderful. The only negative thing I can say about it is that it’s 3m. Hopefully, FiiO will be offering this cable separately in different lengths. If they do, I’ll definitely be buying some! The plug system is great! Basically two plug ins with a lock screw (3.5mm & 4.4mm) with a 6.35mm attachment for the 3.5 and a 4-pin XLR attachment for the 4.4. All bases covered!
On to the headphones….
They’re very well made. It’s almost like Focal & Meze had a baby! The headband is the self adjusting type and is very comfortable. My only concern would be the longevity of the rubber where it stretches. Hopefully, FiiO will offer replacement parts. The ear cups are surprisingly spring loaded. They adjust well in all 3 planes. I do wish that the ear cups were a bit bigger. They are a tight 3 knuckles but okay. All in all, they’re comfortable.
My initial sound impressions are that the FT3 is pretty good. I tried both sets of pads. The suede pads gave a warm presentation. They seemed to add a hump in the lower mid bass and attenuate the treble which resulted in a loss of air. Switching to the protein leather reduced the bass and returned treble airiness. I much preferred the faux leather. With them installed, the FT3 sounded like a junior Elex. (Made a quick comparison)
So now I’m going to let them run in for a bit. I’ll report back in a few. My initial opinion is just get them. Well worth the asking.
Thank you for sharing. I was about to order the r70x but I ended up ordering Fiio's headphones.
I received the FT3 and listened to it over the weekend.
I own a pair of similarly priced headphones, the ATH-R70X, so I primarily compared them to those.
The bass to midrange sounded clearer and more powerful than the R70X due to the faster response time, but it seemed to be trying to stay neutral.
In the treble, they sounded crisp up to the highs, which is where the R70X didn't quite match up, but there was a slightly less polished, more nervous sound that I think some people will like or dislike.
I was reminded of the MEZE 109Pro while listening to these headphones.
The neutral lows, mids, and slightly nervous highs sounded similar, which made the FT3s feel like a mini-109Pro.
Like the 109Pro, which sounded great with some EQ tweaks, the FT3s seem to have the same room for improvement.
How is the soundstage in FT3 compared to r70x?
