[FiiO EM5] Beryllium-coated Dynamic Driver Earbuds
Jan 12, 2022 at 1:41 AM Post #273 of 305
@FiiO Is it possible to buy the foams seperately?
Dear friend,
Yes, you could PM us about the version you need. And which country are you located in now?
Best regards
Jul 10, 2022 at 1:10 PM Post #275 of 305
Hi all. Today I paid attention to the cable of my fiio em5 and found such a speck on the cable. Is the copper oxidized? Will this affect the sound? And does anyone have the same?
Jul 10, 2022 at 2:17 PM Post #277 of 305
Look to be the strains itself being oxidized , yeah… well… I would change the cables.
Cheap cables with silver as a materials will oxidize quickly (most coming from China, except a couple brands from China)
Good and reliable cables don’t come cheap
Jul 10, 2022 at 11:44 PM Post #278 of 305
Dear LinstantX,
copper oxidized-->green
sliver oxidized-->black
So it seems the outlooking of cable stained with blue instead.
Best regards
May 9, 2023 at 12:22 AM Post #279 of 305
got a pair of fiio ff3 last week, and em5 this week
i would have just keep the metal chrome ff3's but i was getting esd static shocks so i thought the resin em5's might reduce it
the ff3's sound better with the foams off and the em5 sound better with them on. so hopefully that also helps my static problem
the ff3's seem to have a bit of a V curve, mids are a bit recessed, then with foams they get way to bassy. so i leave foams off
the em5's seem to lack a bit of bass and mids and have too much treble, so the foams fix the bass and treble issue, then i just eq the mids up a touch
hoping the em5's are my new daily driver, they fit like a glove in my ear, very happy there. Cable is a tad bent due to being in the box which is mildly annoying.
May 10, 2023 at 8:21 PM Post #280 of 305
The cable is great too, very light, soft and no microphonics.
this is false
there is microphonics
the white rubber coating on the cable rubs a tiny bit inside the green earbud resin chamber and creates a subtle ticking sound
its annoying. i would like to put a drop of super glue on the end but im scared that they left it open for bass port exhaust, anyone know?
May 11, 2023 at 12:03 AM Post #281 of 305
this is false
It is the bass reflex port.
May 11, 2023 at 1:23 AM Post #282 of 305
this is false
I think the bass port is the one I marked in your pic. Why you try covering the hole which you indicate with some blu-tack or tape to see if it changes anything before using glue?
May 11, 2023 at 1:26 AM Post #283 of 305
this is false
I did not experience microphonics with EM5, so my post was not ‘false’! Clearly you are having a different experience.
May 11, 2023 at 3:12 AM Post #284 of 305
this is false
No microphonics with my cable. I'm generally not moving when listening, which I find is really the only way to listen listen to earbuds anyway due to the loose fitting. Try listening with them over ears and see if this helps your situation. Improves fit for me.
May 11, 2023 at 10:05 AM Post #285 of 305
ya i dont know if the bottom hole is also needed for bass or not
but i think im going to try a very small drop of dry teflon or silicone lubricant which is safe for rubber, not sticky, quick drying, etc... to coat the place where the cable and resin touch, that way bass can still exhaust if needed
