vipervick
Somewhere between this morning and this afternoon my E17 AUX stopped working. When I went to use it after work, the word "dock" pops on the screen and only 3 inputs are available; OPT, COX and USB. What happened?
Somewhere between this morning and this afternoon my E17 AUX stopped working. When I went to use it after work, the work "dock" pops on the screen and only 3 inputs are available; OPT, COX and USB. What happened?
So I tried to set up the E17+E09K combo with my phone. I docked the E17 in lo-bypass mode to the E09K, and attempted to use it with my smartphone with the USB OTG cable. The phone acts like nothing is plugged in, and proceeds to use it's own speakers. In my ignorance and excitement, I assumed that it would work because the E09K runs off DC power, and the phone would be 'streaming' to the E17 DAC, which in turn would be amped by the E09K.
So what now?
The obvious answer would be to plug a 3.5mm to RCA cable from my smartphone's headphone jack to the AUX IN the E09K. Would I be using the E17's DAC this way? Or would I be double amping?
Another option before I bought the E09K was to track down a Fiio L7 Line Out Dock to utilize the DAC portion of my E17 and let an O2 or something similarly priced do the amping. I can still return the E09K. If I did this, could I then use my smartphone via USB OTG through the L7?
Or is there another way? Thanks in advance!
Did you try resetting it. Most of the problems I had with my E17 goes away after resetting. Hope it's not a hardware related problem.
You need to use the USB to get the digital signal to DAC. AUX wont utilize the DAC.
I don't have E09K but my E17 works fine with android phones. I have tried several ones. You need some player that supports like Onkyo HF player or HiBy Music.
You need to use a OTG cable and connect your E17 to it via usb cable.
***Remember to run the music app first and connect E17 in turned on condition. Or it does not work with most phone.
Let us know if it helps.
Theoretically, everything that gets out of the phone's stereo jack is already amped. So yes, it would be double amped and you won't hear the pure FiiO sound..
yea that should work. Your phone ----> L7 LOD+E17 -----> amp via aux/line in.
I would help you test it out but i don't have usb otg and my smartphone doesn't support it
Good news guys...it's working now!
Xperia Z3 --> USB OTG --> E09K with E17 docked in 'Lo-Bypass' mode.
This is what I did before, but it wasn't working. So what happened here? Why is it suddenly working now? Well, I turned on the E17/E09K before plugging it into my phone. That's literally the only thing I did different, and it's working. I can't believe it was something so simple...
Thanks again for the help guys!
Then playing music in FLAC or Apple lossless presumably would give the most sound quality?
Just wondering if it is worth to change the setup or leave it as it is now - just via USB?
Thank you in advance.
