Im about to order the E17 i just have some questions before i do that.
I recently bought the ATH-M50x and been using it with my PC.Sound is great,but i need a little bit of power,and im sure the SQ will be better with the E17.
Now,do i have to install the ASIO E17 driver?
I use the AIMP3 player,and in the settings it says that it uses WASAPI.I also have ASIO4ALL installed but it is not set on that.Is it needed for the E17 to work properly with my PC?
Also,i plan to get the E09k when i have the cash.I just want the whole package,but how much will i benefit from using the 09k aswell.I do not plan to use the E17 on the go,though i have a rockboxed Sansa Fuze,so i will try it,and if it works well i may just take it with me sometime.
And lastly,since i will have the E17 connected all the time,is this going to be a problem for the battery.
When using the E17 with the USB and set as my default audio device,do i use the DAC only or the amp works too?
