FiiO E12DIY Limited Edition Version---DIY your own sound !
Aug 26, 2013 at 10:25 PM Post #136 of 2,388
updated: we have collect enough pre order for the E12DIY by now, so the project will go ahead and we still collecting the pre-order now.
Aug 27, 2013 at 12:40 PM Post #139 of 2,388
When should we pay the rest of the money?
Thank you very much for this limited edition E12 :) I greatly asume, that it will pair well with the limited ESW11LTD.
Aug 27, 2013 at 10:48 PM Post #141 of 2,388
Thanks, will add it when we back to office, but E12DIY should support all BUF in DIP8 ( single channel ) and OP in DIP8 ( two channels) or SOP8 ( single/two channels ).
E12DIY will comes with some blank adaptor for some SOP8 op amp.
So this will work with 8 pin op amps?
You are quoting the answer to your own question.
Aug 28, 2013 at 11:19 PM Post #147 of 2,388
Am really on the fence between this and cMoyBB, both seems to be solid performer. Mainly looking for amp to power DT880/600ohm from DacPort, listens to instrumental, classical, vocal etc etc. Which route should I go?
Aug 28, 2013 at 11:22 PM Post #148 of 2,388
I don't see a cMoy being able to power 600ohm headphones with the authority they require. If the E12DIY doesn't meet your budget requirements you should consider the regular E12 as well.
