If you can tell us your budget we can give you a better recommendation.
I would suggest the Hifi Boy OS V3.
I bought the Sennheiser M2IEG Momentum on Amazon years ago, they convinced me the excellent reviews they had, I must say that they did not disappoint me.
According to your expert opinion are bad headphones? Do they match badly with the BTR3 they fail to yield its characteristics?
I have not heard the Momentum but it has a good reputation and very positive reviews. If you want to buy something locally maybe you can see if there's a shop in your area that sells the iBasso IT01.Thank you very much, I read some reviews about these headphones, I am very attracted and curious about how they play with my music and how they match with the BTR3.
But I have doubts about the attacks of headphones, I'm afraid that with the constant use of every day you can ruin, I've never had headphones with detachable cable just for this fear.
Another doubt is that in Italy I have no retailer to buy them, the only way is AliExpress with delivery in about 30 days, if I had problems I do not have a warranty or spare parts, given the economic investment I would like to be quiet.
Thank you so much for the precious help
Does this FiiO BTR3 will handle good Sennheiser HD 599 headphones with 50omhs ?
How long can run on battery with this headphones ?, I quess 11h is for earbuds with lower impedance.
FiiO please make that kind of Bluetooth receiver with much bigger battery, for example >500mAh.
I had Sennheiser HD 4.40 BT which work on Bluetooth 25 hours, but I return them to shop, no comfortable for me using at home, so now I want open-back headphones with BT.
Too big, too expensive, I want stick this bluetooth receiver on headphones, and for 50ohms does this BTR3 not enough ?
Sennheiser HD 4.40 BT have built in that kind of Bluetooth DAC/receiver in one earcup and 25hours of battery life of one charge, and they sound perfect .
I had it on my 80 ohm dt770 pro... It wasn't very loud and seemed to sound unstable at Max volume
Dear friend,Hi FiiO, I recently purchased through my official store on AliExpress my BTR3 and I can not wait to receive it because I know it will take from 7 to 14 days because in Italy still no dealer had available.
I have read that a new Firmware - v0912 update is available for the BTR3, but going to download the firmware there are other updates before this! My question is you need to install the old firmware first of the one just released by you recommended ?? Sorry for my english but I'm not native speaker help me with a translator
Will I be able to drive my Audio Technica ATH EQ500's with the uBTR, or will I need the BTR3? I know uBTR doesn't have AptX HD but was wondering if it'll have a lot of the hiss etc, they are really light weight headphones that I love, even though lots of sound leakage etc, its super comfortable..
Got the following specs off the AT japanese site and used google translate
Driver = φ 28 mm
Output sound pressure level = 103 dB / mW
Playback frequency band = 16 to 24,000 Hz
Maximum input = 40 mW
Impedance = 20 Ω
