Strange, just today used BTR17 (fw 1.1) for a call and everything worked.After update to 1.1 stop working voice calls. At screen i saw call icon, but anybody hear me, and i dont't hear anybody
[FiiO BTR17/BTR7] True Lossless Bluetooth, Portable Bluetooth DAC and Headphone Amplifier BTR17 Is Officially Released!
- Thread starter FiiO
Can we all collectively agree that BTR17 would be so much better if we could just double click the volume to change tracks.. please
Deathman666
Agree, it would make life easier with that..
If we're going to ask, I want Fiio to add the Fast Low Dispersion or Hybrid filters.
. Honestly, I use my phone to change songs in bluetooth mode; I don't see the point in the volume wheel having that function. In fact, I almost never touch the device when I can use the control app. Fiio won't do anything we ask unless it's to fix bugs, simple as that.
Not even that, sometimes.
zaznetkherson
@FiiO @FiiO Willson it's realy trouble with 1.1. i'm downgrade to 0.62 and voice calls start working. Update to 1.1 again - stop working
Our use cases are completely different LMAO The main function of a BTR 17 imo is to be portable, and having the volume wheel as a next track button is insanely useful and preferred by many of us. We just need to speak up and hopefully Fiio can work with usIf we're going to ask, I want Fiio to add the Fast Low Dispersion or Hybrid filters.. Honestly, I use my phone to change songs in bluetooth mode; I don't see the point in the volume wheel having that function. In fact, I almost never touch the device when I can use the control app. Fiio won't do anything we ask unless it's to fix bugs, simple as that.
jsmiller58
I’m perfectly happy if they give you this feature since it seems to be incredibly important to you. I will say that for me, I could take it or leave it. But I’d be happy for you if FiiO implemented it.Can we all collectively agree that BTR17 would be so much better if we could just double click the volume to change tracks.. please![]()
amery
I wish they would open-source the firmware
zaznetkherson
Im try update from local to ver 1.1 - voice not working, downgrade to 0.62 - upgrade to 1.1 from App - all same. At 1.1with android 13 at activa call not sound at headphoneStrange, just today used BTR17 (fw 1.1) for a call and everything worked.
Try to update to firmware 1.1 and shut down. Power on the device and do a factory reset. Shut down again, power on and try.Im try update from local to ver 1.1 - voice not working, downgrade to 0.62 - upgrade to 1.1 from App - all same. At 1.1with android 13 at activa call not sound at headphone
FiiO Support Lin Lin
Sponsor: FiiO
Dear friend,If we're going to ask, I want Fiio to add the Fast Low Dispersion or Hybrid filters.. Honestly, I use my phone to change songs in bluetooth mode; I don't see the point in the volume wheel having that function. In fact, I almost never touch the device when I can use the control app. Fiio won't do anything we ask unless it's to fix bugs, simple as that.
Hi, we have reported your feedback to the engineer. They need to assess about that first.
Best regards
Sponsor: FiiO
Dear friend,@FiiO @FiiO Willson it's realy trouble with 1.1. i'm downgrade to 0.62 and voice calls start working. Update to 1.1 again - stop working
Hi, you are using USB or Bluetooth connection? We did not fix anything about calling in V1.1. You could try to adjust the volume in your mobile phone to higher level while calling to check again.
Best regards
Please make the volume wheel double click to change tracksDear friend,
Best regards
zaznetkherson
@FiiO Support Lin Lin Thanks for support. I'm using bluetooth. Try reinstall 1.1 again, after that reset to factory, clear paring, nothing change.Only silent at headphones BUT , it very interesting. After off and on again all start working!Dear friend,
Best regards
