Thanks for the reply. Do you know a good EQ for Android that will work for both local files and streaming apps?Yes, but you can EQ it on the smartphone (assuming that's your source).
[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
- Thread starter FiiO
dan
- Feb 25, 2002
Now that I'm home things should be much better.
I'm fully enjoying the BTR5 with 2.5 Tripowin cables for my TRMS 4 Pros. Super wide sound stage. Like I'm with the guys on stage. Zonie 16 Core.
Waiting for the break of day.
Very good separation.
Tired of lying in the sunshine.
No idea, sorry. I have an Sony Xperia and it already has Sony own EQ system built into the smartphone.
whoking
- Mar 22, 2004
Yes it works great in my car through the AUX input. My car only allows 1 BT connection and I play music from my M11 to the BTR5 to eliminate a cable.Has anyone used this in there car, by plugging into the AUX cable of there sound system? Currently have a parrot system, which unfortunately doesn't have any of the top BT codecs, such as AAC.
jsmiller58
I use my BTR5 with my LG v30 phone. I set the LDAC rate to 990 in developer settings. Is there anyway to actually confirm that this is the setting being used by the BTR5?
hifi80sman
Curious...is the 3.5mm slot a little "soft" for anyone else? In other words, there is typically a satisfying "click" when inserting the cable into a 3.5mm jack, but in this case, there is no click and it's simply a firm, but soft, push.
Sound Eq
- Nov 9, 2013
how would the Fiio BTR 5 compare to something like ibasso dc01 dongle to use with a galaxy note 10, in terms of sound quality performance only, to use with iems only
psikey
- Jul 15, 2008
Probably a stupid question, I apologise in advance, but I am confused since I have seen people doing this:
Can this thing drive an HD6XX? I guess not, but, I was wondering if anyone tried it, thanks!!!
Easily, especially if using balanced cable.
Aevum
- May 15, 2007
Im tempted to get one, but at the same time im thinking...
This is only a couple of bottons, and a MicroSD card slot from a pumped up M5, wouldnt it be a better device ?
psikey
- Jul 15, 2008
What microSD slot? This sounds better than a "Pumped up M11" or Hiby R5 or Dragonfly DAC/AMP IMO let alone an M5.
The main point is most of us have a decent phone with plenty of storage these days and UI/screen/speed better than any DAP.
With Android phones & LDAC BT 660/990kbps sound quality is approaching quality of wired so why have another bulky device. iPhones not so good with BT but latest do have aptxHD. Plus can also connect wired for full bit-perfect playback.
In my case I have an excellent 512GB Samsung S10+ with a 512GB mSD so vast amounts of storage for my own files and offline streaming music files.
PS. If you didn't twig from my first line the BTR5 or BTR3 or ES100 type devices have no internal or mSD storage at all. They are BT/wired DAC/AMPS with volume & playback controls.
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
This ^
hifi80sman
When using the 3.5mm jack, is there a "click" when you insert or is it kinda soft/mushy? Mine works, but I want to make sure it's not defective.Easily, especially if using balanced cable.
psikey
- Jul 15, 2008
Like in any other 3.5mm jack, a click as end locks into place, not mushy, but not totally clear what your asking.
hifi80sman
On my unit, there is no click when the ends are in place (tried numerous 3.5mm male ends), it's just kind of slides in and out with no click securing it. It works and it's not loose, but it's also not clicked into place. I was wondering if it's just my unit or a common manufacturing issue.Like in any other 3.5mm jack, a click as end locks into place, not mushy, but not totally clear what your asking.
abitdeef
- Oct 30, 2003
My 3.5 clicks in also and is pretty tight.
