[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
Oct 24, 2021 at 9:58 PM Post #2,731 of 3,670
@FiiO any chance to get "USB Audio Adapter" mode for the original BTR5?
Thanks for the kind feedback.
We will report to the product manger for assessing about that.
Best regards
Oct 26, 2021 at 2:44 AM Post #2,733 of 3,670
BTR5 2021/BTR5 2021 L-C are on the way to our worldwide sales agents!
Dear respected customers,
Thank you for your kind patience and constant attention for our BTR5 2021. Delivery of the BTR5 2021 has started from 25th, October. Please kindly check this post for a daily updated list of countries / regions and agents we have sent goods to.
Thailand: Holysai
USA: USA distributor
HongKong: Carve Link Company
Germany: NT Global Distribution GmbH
TaiWan: Taiwan distributor
Australia: Addicted To Audio
France: Son Video
Switzerland: Portacomp AG
Netherlands: Fiio.nl
UK: EA Audio
Canada: Canadian distributor
Mexico: Audiofilia Mexico
Bulgaria: Bestline l.t.d
Romanian distributor: AVstore
Turkey distributor
Poland: Audio Magic
India: Headphone Zone
Ukraine: Avero
Lithuania: UAB Audio guru
Japan: Emilai
Estonia: Mamear AS
Poland: MIP
Finland: Hifitalo.fi
UKraine: TOV “ELTO” , Avero
Turkey: Hes Audio
Norway: Siv. Ing. Njål Hansson AS
Belarus: Magnit Invest
(* The shipping to other regions will also follow soon, and we will keep updating this post)
In order to get prompt pre-sales and after-sales service, we strongly suggest you to buy FiiO products from our authorized sales agents (Where to buy).
By our estimate, it would take 8 to 12 working days for the parcels to reach our agents abroad, which means all of you can try contacting the local sales agents on about 3rd November.
If you have any comments or questions, please feel free to contact us or directly contact our local agents.
Happy listening!
Best regards,
FiiO Electronics Technology Co., Ltd.
Oct 26, 2021 at 6:28 AM Post #2,734 of 3,670
Can you stream music such as Tidal when using as a dac. I want to be able to connect to my iPhone 12 and listen to music using the mqa through Tidal. What cable can I use to connect the iphone to the Btr 5 2021?
Oct 26, 2021 at 7:21 AM Post #2,735 of 3,670
Yes, it should work with Tidal and MQA. You need the BTR5 2021 L-C version which comes with a lightning cable or you can buy Fiio LT-LT1 cable separately. There are also other brands of lightning to USB-C cables out there.
Oct 26, 2021 at 9:23 AM Post #2,737 of 3,670
Yes. MQA works if connected via the cable to iPhone. Make sure you have Fiio's lightning to USB C cable as Apple's cable that comes with iPhone doesn't detect the DAC.
Oct 28, 2021 at 2:47 AM Post #2,739 of 3,670
Oct 29, 2021 at 10:35 AM Post #2,743 of 3,670
I found headphones Meze 99 neo that you can purchase a 2.5 mm balance cable for. I plan to connect the headphones to the BTR5 2021 throught the 2.5 mm jack. If this is connected to my iphone 12 then the sound should be balanced. Is this correct.
Oct 29, 2021 at 11:01 AM Post #2,744 of 3,670
Yes, that would be balanced.
I don't see the point in this, though... The balanced output is for high impedance / low sensitivity 'phones. The only difference between the balanced and single-ended is that balanced is 6dB louder. It shouldn't be necessary for those headphones.
Oct 30, 2021 at 6:40 AM Post #2,745 of 3,670
I get a second hand Aria and hears static noise on some song, i thought it was my second hand aria or its old balanced cable that making the noise
After changing cable, tips, filters, and sources, it seems its the source that cause the noise.
apparently my BTR5 develop static noises and it getting somewhat more audible in many songs.:sob:
is there any fix for this?
