scarfacegt
- Nov 4, 2010
Can i use the btr5 as an dac with my samsung note 10 plus and ifixcan? btr as dac an xcan as amp?
I think saw Zeos use BTR5 as DAC and then connect it to Oppo Amp or he use different bluetooth dongle to that oppo ampCan i use the btr5 as an dac with my samsung note 10 plus and ifixcan? btr as dac an xcan as amp?
Haven't heard it, but some store owner points out IFI to me for upgrade from my Dragonfly black or BTR5.Has anyone heard the Ifi audio hip dac 2. Is this better or same as btr5 2021 relative to sound quality
Dear friend,I get a second hand Aria and hears static noise on some song, i thought it was my second hand aria or its old balanced cable that making the noise
After changing cable, tips, filters, and sources, it seems its the source that cause the noise.
apparently my BTR5 develop static noises and it getting somewhat more audible in many songs.
is there any fix for this?
I tried it with both 3.5mm and 2.5mm and both have occasional crackling noise.Dear friend,
Which output are you using? And does the same issue remain when using another headphone?
Best regards
Hello guys.
I was just wondering how is BTR5 paired with Fiio's FD5?
I was just considering it as my on-the-go solution...
Hello guys.
How about the new version, I don't think there's a big difference, only MQA added and newer ESS chipBTR5 (old version) is very linear and neutral so it is a pretty good match with everything so I wouldn't worry.
Power from the balanced output is more than enough.
