Move your Music in Summer! Flagship Portable HiFi Bluetooth DAC and Amplifier BTR5 2021 Is Coming!
In this autumn carnival, we should let ourselves out. FiiO’s new release, the BTR5 2021, the flagship portable HiFi Bluetooth DAC and amplifier will be there to really make your music come to life.
Fresh and quiet autumn days will not be short of pure sounds. The BTR5 2021 comes with two all-new ES9219C DACs, ensuring low power consumption yet with high SNR for wireless new sounds. Better performance, stronger decoding capacity.
With a new DAC scheme, the BTR5 2021 supports MQA Renderer, so that it can unfold MQA tracks on your mobile phone, allowing for rich, master-quality sound reproduction with high sampling rates in manageable file sizes.
In daily usage environments, the BTR5 2021 can work as a USB DAC/Amp. It supports a switch to the USB DAC/Amp mode by just a single tap. If a USB connection is detected, a selection menu will automatically pop up on the screen. At this time, press any button to disable the charging function and enter the USB DAC/Amp mode.
Keep features of the BTR5 2021 include:
--Dual high performance ES9219C DACs
--Qualcomm CSR8675
--XMOS XUF 208
--Supports MQA Renderer
--3.5mm+2.5mm headphone outputs
--FiiO Music App smart control
No more hesitation. Just refresh your music library and discover more surprises with the FiiO BTR5 2021.
--Qualcomm CSR8675
--XMOS XUF 208
To find out more about the BTR5 2021, please visit the product page on
The BTR5 2021 is now available on our AliExpress Official Store. Click the link below to take it home right away:
https://www.aliexpress.com/item/4000316761086.html?spm=5261.ProductManageOnline.0.0.15744edfxfUxvM
Does the 2021 version have better BT range than the original? I'm wanting to upgraded from the BTR3K, but need the range to be similar.
Same as the BTR5.Does the 2021 version have better BT range than the original? I'm wanting to upgraded from the BTR3K, but need the range to be similar.
Best regards
shyamelge
- Jul 29, 2013
Because of the same BT chip used in the 2021 model, the BT range would be the same. The newer Qualcomm chips (such as QCC5120, 21, 25...) have a far greater range than CSR8675. The newer chips are also more power-efficient. Look out for newer chips if the limited BT range of CSR8675 is a concern.Does the 2021 version have better BT range than the original? I'm wanting to upgraded from the BTR3K, but need the range to be similar.
kgs51
- Oct 30, 2015
Are you aware of models today that have those chips. My understanding is the range now for this is only 15 feet.Because of the same BT chip used in the 2021 model, the BT range would be the same. The newer Qualcomm chips (such as QCC5120, 21, 25...) have a far greater range than CSR8675. The newer chips are also more power-efficient. Look out for newer chips if the limited BT range of CSR8675 is a concern.
shyamelge
- Jul 29, 2013
many products released in the past couple of months have newer chips. For instance, Shanling UP5. In this category, Qudelix 5K was perhaps the first one to use the newer chip.
kgs51
- Oct 30, 2015
How would you compare the BTR5 to the Shanling UP5
Does it support MQA in bluetooth mode?The BTR5 2021 is now available on our AliExpress Official Store. Click the link below to take it home right away:
SenorChang8
MQA only works via USB.
sg2k
- Dec 18, 2012
With the 2021 Version is Dual-DAC Mode working with Single-Ended or only with Balanced Output like V1?
Aevum
- May 15, 2007
is the fiio website down ? tried to download the latest firmware and it tells me site expired.
stuck limo
Formerly with Light Harmonic/LH Labs
- Feb 6, 2016
I'd like to know this too. I bought the BTR5 but am wondering if I should have gone with the UP5 instead.
jsmiller58
There is a Shanling UP5 thread here on Head-fi, and last time I was on it (some time ago) there were comparisons to the BTR5 and the Qudelix 5K. You might want to check there as well.I'd like to know this too. I bought the BTR5 but am wondering if I should have gone with the UP5 instead.
Same as BTR5.
Best regards
Total: 7 (members: 0, guests: 7)
