kenman345
- Nov 22, 2011
AS-2's are not cold at all. They're lively to say the least. It's hard to find something that sounds bad if the mastering is good and the source file is good-great quality. 192kbps or lower sounds terrible out of the AS-2's I have. Absolutely terrible. It wouldn't even take a trained ear to hear the difference.
That's just kinda how they are, to a point.
If you don't already, just burn them in non stop. 140+ hours on mine and they sound much better than they did the first week.
Honestly, i like my ASG-1s, and after burn in they no longer are frustrating to listen to - but i wouldn't hesitate to try the ASG-2s. The ASG-1s are unique, and have a lot of merit in sound stage, bass extension and resolution; as well as tonality. If the ASG-2s hold all the best qualities of the 1s but with higher fidelity to the highs (not sparkle, but more defined and neutral) then they'd be ideal.
The ASG-1 as it is is relatively close to what i would consider ideal, if there was a tad bit more treble - which would essentially make them more neutral. I don't want sparkle, or a cold analytical sound, simple slightly more definition to the music, a little more space and detail that would be level with the lows and lower mids.
