Have no idea what is singing But by the looks of those good people they can sing whatever they want and I am not going to argue with them. Gumby is doing fine and I have used it with speakers and it has made a difference in what I'm hearing on the speaker system. Clarity is great and it adds just a very small Touch of warmth to the solid-state amplifier I am really enjoying this.
Hi UT, a little question for you. Does the Euforia have a user changeable fuse in it? Amp was playing fine, using pre-amp out about two hours ago. Just went to turn it back on, and nothing. No pilot light, changed tubes no thing. Unplugged and removed tubes did smell check and no burn smell at all. Was using Sylvania 6an7gt's and Raytheon 6080, no apparent problem listened for a couple of hours, not any warmer than usual. Now nothing. Before I open it up wanted to check and see if you knew about possible user fuse inside. If not have to send back to Poland I guess. Thanks UT.
Would have been a good idea for feliks to put fuse info in product brochure since it is user replaceable. I can make out part of it looks to be 250V but first part can not make out even with magnifiy glass.
Whirlwind, are you still enjoying your Draug 2 cable on the 800's? Have been thinking along those lines. Thanks for the info on the fuse, looked right at it, but with the trap door around the side, it is well hidden. Nice design, fit and finish.
Surprised the fuse blew, but it happens. Glad it was an easy change. Have to pick up a few, just in case it happens again, but if it does, may want to return it to find out why, if it happens again. That is a nice looking cable, I like the Senn cable but it is just so long. Could cut it and re-terminate I suppose, but then if I sold it would want stock cable to go back on. Thanks again for the fuse info, appreciate it.
