Deleeh
Hello,
Thank you for your answers.
@mordy
Originally I wanted to use this one.
https://www.acinfinity.com/componen...ponent-cooling-blower-system-rear-exhaust-17/
And this is the one I meant it only comes with the us plug.
I misspoke on the article, sorry.
@connieflyer
Strictly speaking, you're right about the transformer - I didn't take that into account.
The second thing would be possible vibrations that could possibly be transmitted to the wood, I just thought of that.
I understood the cooling concept to be that air is sucked in at the top and the exhaust air takes place at the bottom.
I ordered the socketsavers last week and they should arrive this week.
I hope it will be a little better with them.
Otherwise, the Euforia stands freely on a slate plate and is raised by 1 cm.
If I open the window to ventilate during the warm-up phase and listen for 2-3 hours, it works.
If it runs longer, I have to ventilate a little in between so that there is fresh air in the room again.
In winter, I have to be a bit careful because the room is also small.
My thought was more to be able to remove the warm air, I did not take into account that it rises upwards.
Obviously I still have two or three small mistakes in my idea.
It still helped me to rethink the whole thing.
Thank you both.
I use the 6080 and the 6SN7, and you are right that they do get quite warm.
The 6080s give off more heat and they heat up faster than the 6SN7s, I have noticed.
Edit:
Purely informative, the repair processing at Feliks went without major problems and reliably.
They were also relatively quick.
All in all, from the time it went on the road until it was delivered back to me, it took just under 2 1/2 weeks.
You have to add 3 days of shipping per shipment from Germany to Poland.
Absolutely justifiable for me and of course a great performance by Feliks when you have the possibility to send it from Europe.
Depending on the country, it can take a little longer, France, Italy, Spain, England.
Definitely better than going via the dealer who then sends it to the general agent and only then goes to Poland.
Even though it may sound stupid, I remember it sounding better than when I bought it.
But that could also be deceptive, as I listened to the transitional period with a Solid State and the Little Dot 1+ and my ears have become accustomed to the sound.
Great work by Feliks, all handled in a very customer friendly way.
It would be nice if other manufacturers would take a similar example.
There is no need to worry about this.
I am very satisfied and happy to have the Euforia with me again.
As a final tip when sending.
It is not absolutely necessary, but a lot also happens during shipping.
When sending to Poland, it still makes sense to send with insurance.
In case something should happen, you are covered.
In Germany, the package still goes to the recipient, who is the repairer in this case and can make an estimate and settle the damage with the shipping company, who reports it to his insurance company.
I suspect that it is similar in other countries and parts of Europe.
@mordy
@connieflyer
Thank you both.
Edit:
