Hi All,
The Sylvania 6080 tubes I like are 6080WB from the early and mid 1960's. The Philips 6080WC ECG tubes are from the early 80's(!) - I guess an end of an era.
The Sylvania Gold Brand 6080 tubes have no suffix, and I can't figure out the date codes: One tube is marked ECT CM and the other ECS AF. These date codes remind me of a Sylvania 12AU7 tube that I have that has the date code XYZ......
They all look very similar except that my early 60's tubes have a gray plastic base instead of black. Perhaps looking for a gray plastic base will help you locate the ones I like the best if you want to try them.
Now, about analyzing how they sound I have come to a stage where I am not bothered by anything; I just enjoy the music. These tubes (with the C3g drivers) just sound right with very detailed and strong bass. Don't know why, perhaps because the C3g driver tubes are powerful enough to drive the LD MKIII by themselves , but I can switch off the heaters from the 6080 tubes (shutting down the external PS), and the amp still makes enough signal to work as a preamp with a ss amp, although not enough signal to drive the headphones. I just have to turn up the volume on the ss amp.
This way I can directly compare the sound with the 6080 tubes working and without. Early on there was an opinion on this forum that power tubes contribute some 15% to the overall sound. This is not true IMHO. Using these 2.5A power tubes together with the driver tubes changes the entire sound picture. The best analogy I can come up with is a tepid soda pop that's flat without carbonation, and a cold one with all the fizz in it. Or, grape juice vs a good wine - you get the idea. It's totally different, and everything is affected.
And yes, I am contemplating an Elise. The question I have is if it is going to be a quantum step above my current set-up. On the other hand, there is nothing so good that it couldn't be better.....
Then there is the question if I should order an Elise made for C3g drivers instead of the 6SN7. This would exclude driver tube rolling but maybe the sound would be superior.
Cheers,
Hi mordy.
I can fully understand your plight re. whether to take the plunge or not...I had to think long and hard before putting the suggestion to the Feliks guys - as you know I had pushed my LDMKIV SE pretty well to the limit with the C3gS/GEC CV2523 combo, and I do believe the SE is possibly a notch up from the MKIII!
There are a good many factors to consider here - I shall try to put some of them into perspective...
1. To get a
quantum leap up you would need to spend a GREAT deal more than $500, I suspect. However, the Elise is definitely in another league IMHO.
2. Although our LDs are able to take the punishment of using these more 'exotic' tubes, I truly believe it is only a matter of time before something gives out - especially the MKIII that gets much hotter than the MKIV SE (and although you use a cooling fan, surely the components are still operating at a much higher temp. than spec...). And so looking to the long-term future, I wanted rather more security/safety. Plus even though our external PSUs and regulators do the trick, a proper dedicated PS is probably the better option...
3. The aesthetic factor, which of course is a very personal thing - even though I had managed to hide the 'extras' fairly well, I still wanted something neater.
4. Other elements of the set-up will also, naturally, come into play. Source upgrades I feel benefit the Elise more than the LDs, but more so headphone upgrade. Although, for example, the HD650s up their game accordingly, the improvement is much more dramatic with the likes of the Beyer T1s or HD800s. So this does of course bring in the extra cost factor - but again looking to the long-term can help in such decisions (I myself never thought I would spend more on HPs than the amp, but boy have I learned a lesson...I wish I'd done it sooner!).
5. How much further experimentlng with different tubes in the LD is anticipated...BOTH could be an option also!
I'm sure there are other factors to consider, but I think this post is long enough already!
I wish you all the best in your deliberations mordy - and probably a few more peoples' impressions would be very helpful also...
ps. I have a feeling it could be a long while before Lukasz would even reconsider the solely C3g configuration...it's still relatively early days in original remit production after all!
CHEERS
CJ
Edit. pps...I also REALLY like how the Elise's case AND trafo housing get just barely warm!!
