Hello Hypnos1 and everybody! I'm the lucky guy who won the Elise in the raffle. I've now gotten it home today installed the tubes and powered her up, but I'm having a problem. I get some hum when there is no sound, but I'm reading this is normal, so not a problem, though when listening to the hum there are sometimes blips and glass tap kinds of noises that change in character, so maybe still a problem. There are a couple things that I can't figure out. I'll email Lukasz tomorrow and see what he says.
1. If I hook my DX50 to the back and play music with the volume turned all the way down on the Elise, music comes out, and it sounds relatively clean but really quiet, same with the Geek Out 1000.
2. If I turn the volume up, the hum increases, but the volume of the music doesn't.
I've made sure the tubes are in their sockets right and my RCAs are well connected, but I can't figure out what is causing this hum and lack of ability to change music volume. Neither of the DACs I'm sending music out from have true line-outs, but I've done the standard thing and maxed out the volume from the source to emulate line-out.
Hi glassmonkey.
Congrats on winning the Elise...now we just have to see what's going on!
Can't really add much to what gibosi has said...mine does indeed hum a little at first, but disappears completely when the signal cuts in. It certainly sounds like you just aren't getting a proper line in signal - hopefully you can find/beg/steal/borrow something suitable! (Don't mean to insult you mon ami, but you are using the correct RCA sockets?!
I'm sure there is a fairly simple explanation for this...and whatever it is, it will get sorted in the end.
Here's hoping for a speedy recovery!
Cheers for now.
