mr.karmalicious
- Nov 4, 2004
I'm using an ES100 so it's 2.5 or bust for me. Would like a right angle connector too, but it seems like 2-pin + 2.5mm is rare enough already...
Over thing making me mad is that DAP makers are starting to have higher end models be 4.4mm and lower end 2.5mm.I'm using an ES100 so it's 2.5 or bust for me. Would like a right angle connector too, but it seems like 2-pin + 2.5mm is rare enough already...
Is there... A reason? Aside from durability? Seems to me like given identical performance you should just use the smaller one.Over thing making me mad is that DAP makers are starting to have higher end models be 4.4mm and lower end 2.5mm.
It sort of makes sense when there are space constraints, but 4.4mm should just be the future.
Everyone just needs to adopt it and stick with it or I'm going to overflow with cables.
You can just use an adapter - either 2.5mm balances female to 4.4mm male or vice versa.
The cowon plenue d2 I had was super tiny as well and had a 2.5mm port.yeah, my lil baby ES100 only has room for a 2.5, especially since it also has a 3.5
I just got my S6 in today. All I can say is, HOT DAMN!!!
Hot damm comparing to what?
Cool.
Enjoy. Sexy as fuuu
