FEARLESS Audio IEM's Discussion/Impressions
Dec 24, 2020 at 6:27 PM Post #5,116 of 5,206
I've read that Conductor have better impact bass than EJ07, and EJ07 have more rumble.... I think Conductor could be another good choice. They are both at the same price.
EJ07 is the 2019 flagship, Conductor is the new 2020 flagship, right?
Dec 24, 2020 at 6:42 PM Post #5,117 of 5,206
Yes, that is correct. But keep in mind that newer isnt always better.
Dec 24, 2020 at 7:02 PM Post #5,118 of 5,206
Dec 24, 2020 at 7:32 PM Post #5,119 of 5,206
Yes! I had won the 30% discount on Linsoul when I purchased the S8Fs on 11/11 event.
EJ07 or Conductor?
In your opinion, is it difficult to sell one of them (EJ07/Conductor or S8F)? Because I will not keep them all.
The S8F is probably? the easiest to sell, due to its lower price, and probably more mass appeal, but the EJ07 certainly has a loyal following and enthusiastic fans. If you sell an EJ07 for 30% off MSRP here, it should be a pretty easy sale, to break even.
Is the 30% off only for the EJ07 or Conductor?
You should sift through this thread.
https://www.head-fi.org/threads/shuoer-impressions-thread.916267/
The Conductor was eagerly anticipated, but never caught on. The EJ07 is still the popular one.
Dec 24, 2020 at 8:59 PM Post #5,120 of 5,206
The 30% discount is for any products on Linsoul, I can choose whatever product I want. Do you have advice other than EJ07 or Conductor? Now I go to read the thread you posted me, thanks.
Dec 24, 2020 at 11:10 PM Post #5,121 of 5,206
There are some other possible options. PM sent.
Dec 25, 2020 at 2:43 PM Post #5,122 of 5,206
Can you get 30% off the Monarch? How did you come by this discount?
Dec 25, 2020 at 3:34 PM Post #5,123 of 5,206
I won the 30% discount code on the Linsoul 11/11 lottery.
I think I will go for the EJ07 btw... I need to dig more.
The alternative to those IEMs could be a new DAP... But I'm really loving my Lotoo Paw S1 dongle that works very well.
Dec 27, 2020 at 12:58 PM Post #5,124 of 5,206
As it turns out, I like the S8 Pro mostly for vocals, classical, jazz, acoustic music. While rock, pop, metal, EDM also sound good on it, I prefer quite a bit more sub bass, with the characteristics of a DD.
Dec 27, 2020 at 4:32 PM Post #5,125 of 5,206
Hi,
I've been using my BVGP dm6 for a while now and decided to finally upgrade! I did a decent amount of research into the fearless s8 family and arrived at picking up the s8z, I have heard they are pretty sensitive IEMs, I currently own a thebit Opus #1 DAP as my portable setup and a ifi Micro iDSD Black Label has anyone used these setups with the s8z's before? Hopeing to not have static/hiss.
Thanks
Dec 27, 2020 at 4:35 PM Post #5,126 of 5,206
Hi,
Thanks
Go with the Rui or the Z
Z has more detail but Rui just Rocks and is warmer. Sometimes less is more
Dec 27, 2020 at 8:20 PM Post #5,127 of 5,206
The Rui is s6, for s8 equivalent of Rui is s8Freedom. Just to avoid the confusion.
Dec 28, 2020 at 9:15 AM Post #5,128 of 5,206
Finally I received my S8F. They have replace them and sent me a new sealed set! Wow.
Unfortunately they hurt too much my ears. I tried to use them a couple of hours and my ears were bleeding.
They are too bright for my taste and bass aren't punchy enough.
I bought them for prog metal, djent, metalcore and those very busy tracks and I can't listen to those subgenres. Maybe they are good with electronic?
I'm very sad right now because I was very excited about these IEMs. I sell them and looking for something else.
Dec 28, 2020 at 9:30 AM Post #5,129 of 5,206
Surely my ears are the problem, because there are all good reviews and many enthusiasts of the S8Fs.
Dec 28, 2020 at 9:46 AM Post #5,130 of 5,206
I don't like that pair at all. They are V shaped, have pushed high mids and pushed midbass since the BA can't hit DD slam levels. Just bad for the music I enjoy which has a lot of midrange.
