FA7, the first Quad drivers IEM from FiiO , all Knowles BAs and 3D printed technical , MMCX design
- Thread starter JamesFiiO
magicalmouse
I'm not too sure why there are not more positive comments, the fa7 sound warm and cosy with the right eartips, i use spinfit cp24 and they fit me well
d
d
sidecross
I would agree I have three fiio iem's fa1,fh5, & fa7 and the fa7 is what I choose most often.I'm not too sure why there are not more positive comments, the fa7 sound warm and cosy with the right eartips, i use spinfit cp24 and they fit me well
d
I might add for the poster from France the fa1 and fa7 have nearly the same size nozzle and if a fit for fa7 is problematic the fa1 will not be an improvement for fit.
HaBo
Thanks for your answer but my fitting problem is not about the nozzle but with the rear of my concha.
sidecross
In that case the size of the body of fa7 is only slighly bigger than fa1; the fh5 is on the other hand much larger than fa1 & fa7Thanks for your answer but my fitting problem is not about the nozzle but with the rear of my concha.
Wernersound
Hi there, very interesting reading your posts here. Based on your comments i bought first the fa7 and then btr5 (i had the btr3) and se cable. What a difference spacious sound between 3 and 5.
i had lots of fun listening the fa7 but now i have little problem the left fa7 doesnt work there is something with the connector i think. The problem is also with 3.5 cable. When in look inside the connector i dont see something. Any tips other then sending it back to fiio?
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Tried a different cable? Also tried contacting the dealer you got it fromfor a replacement?Hi there, very interesting reading your posts here. Based on your comments i bought first the fa7 and then btr5 (i had the btr3) and se cable. What a difference spacious sound between 3 and 5.
Wernersound
Hi thanks, yes tried an different cable and send an mail to FIIO.
The issue doe not locate in the other cable, right? If the headphone is still within the warranty, you could try to contact the seller for help first.Hi thanks, yes tried an different cable and send an mail to FIIO.
And you could also try to gently pry the small, notched ring on the MMCX's head into a larger diameter to see whether it could help?
Best regards
Wernersound
Best regards
Hi, thank you for your reaction! Indeed no problem with the cables. Tried both your cables se and 3.5. Did make the ring a little bigger, still no sound. Was worth to try. I will contact the seller.
Wernersound
Went to the seller. They ch
Went to the seller and got a new oneHi, thank you for your reaction! Indeed no problem with the cables. Tried both your cables se and 3.5. Did make the ring a little bigger, still no sound. Was worth to try. I will contact the seller.
Ok,thanks for the feedback.
Best regards
Best regards
HaBo
Where can I find the impedance curve of FA7 ?
sidecross
Fa7 is 23 ohms the 'curve' is beyond my knowlwdge.Where can I find the impedance curve of FA7 ?
