FA7, the first Quad drivers IEM from FiiO , all Knowles BAs and 3D printed technical , MMCX design
Aug 12, 2020 at 2:59 PM Post #661 of 680
Just received my FiiO FA7's, and after about 3 hours listening to them, I can say these remind me of my beloved Audeze LCD-2C's - and that's a compliment. I don't find the bass too much, just a bit warmer than neutral, but with enough detail. Vocals, and female, are well handled. High's maybe a tad rolled off, but it beat too hot in my opinion. And I find the fit and comfort level outstanding. I may be keeping them.....
Aug 12, 2020 at 6:30 PM Post #662 of 680
I kept mine and found the fit the best of what I have ever tried. I alternate for music the fh5, fh7, sony mdr 1am2 powered by fiio q5. I ordered the fh3 and hope it ia a composit of the best of the fh5 and fa7. :)
Aug 31, 2020 at 9:30 AM Post #666 of 680
Sorry it's not my ears it is the fact that if the fit is loose on the iem stem it may get lodged in the ear after extraction
d
I had that problem with the DM6's. Their eartips came right off the stems, and one did in fact lodge in my ear (wife had to use tweezers to pull it out). Never had that issue with my FiiO FA7's. But I went on Amazon and spent $5 on a set of 5 small eartips (the size I use) and they fit the stem nice and tightly and I've had no issues since. So maybe try some aftermarket eartips......
Jan 31, 2021 at 12:48 PM Post #667 of 680
Can anyone tell me of I have (Oratory1990)
copied this correctly?
https://www.dropbox.com/s/13jx6v9c9k4drfn/Fiio FA7.pdf?dl=0
Feb 3, 2021 at 7:08 AM Post #668 of 680
bump
Mar 25, 2021 at 6:02 AM Post #669 of 680
Apr 2, 2021 at 5:39 AM Post #670 of 680
Questionnaire About Earphone Types(Note: that this questionnaire is not limited to earphones of FiiO brand)
Distinguished users,
To better know your preference and design suitable earphones for you, we made this questionnaire about earphone types and would like to sincerely invite you to participate in it. Thank you so much for your support and advice.
>>>Click here
Apr 2, 2021 at 10:40 AM Post #671 of 680
>>>Click here
It shows blocked?
Apr 3, 2021 at 4:14 AM Post #673 of 680
