Anyone know?![]()
"Specific" MMCX connectors with the right clearances- yes
Anyone know?![]()
Anyone know?![]()
Ok thank you both! Guess I need to go searching this thread for some good, cheap cables. I was hoping for one that had interchangeable tips like Dunu but I suppose that is out
Yep... Sennheiser use the fidelity+ mmcx connection with a reassessed socked. In short, you need to buy a adaptor. Just look up eBay or Amazon for IE300 adaptor.Anyone know?![]()
I'm glad I don't have that ability because it would cost me more money continually buy more gear.I envy you guys that can hear sound differences in cables like that. I wouldn't mind having that ability.
I think the angled are a bit more comfortable. It does add an additional pivot point, which can be irritating at first when you are trying to get used to them. I leave them on the IEM with the thought that the burden/wear of switching is then placed on the adapter and not the IEM. Probably doesn't make much difference, who knows.What do you find is a more comfortable fit the straight or the angled connector while using the utws5 ?
OK thanks, I ordered straight ones before I read this but can still get the angle ones later. LolI think the angled are a bit more comfortable. It does add an additional pivot point, which can be irritating at first when you are trying to get used to them. I leave them on the IEM with the thought that the burden/wear of switching is then placed on the adapter and not the IEM. Probably doesn't make much difference, who knows.
You will be fine with those I think. I don't notice hardly any difference, and those are what I have been using mostly too.OK thanks, I ordered straight ones before I read this but can still get the angle ones later. Lol
The ones I ordered are off aliexpress, the same seller you got your mini ones from but I bought the black ones that are 12.8mm long.You will be fine with those I think. I don't notice hardly any difference, and those are what I have been using mostly too.
Let me know if this doesn’t work for youThe ones I ordered are off aliexpress, the same seller you got your mini ones from but I bought the black ones that are 12.8mm long.
I am wondering if they will fit in the case being a little bit longer than your ones.
I will be attaching my ie300s to them instead of my IE600s as I use my IE600s on my ifi signature. Can you measure your mini straight connections when you get time please so I can workout weather they will fit the case
Thanks Grant.
What would work better would be the measurement length of one of your mini straight connectors & the distance from your ie600 to case clearance. (Gap) Thanks again.Let me know if this doesn’t work for you
How’s this? There is actually quite a bit of room left.What would work better would be the measurement length of one of your mini straight connectors & the distance from your ie600 to case clearance. (Gap) Thanks again.
