- The entire ER4 line have removable cables, though there's physically quite a bit more friction to it when compared to IEMs that are billed as removable-cable type.
- ER4P/PT is nice to have the 'option' of turning it into an ER4S with the adapter cable, but if you're seeking pure sound quality, you'll always be using the adapter. My ER4S wasn't hard to drive out of my Sansa Clip on ReplayGain'd files.
- The ER4 line is definitely more sturdy than the HF line cable-wise, but at a steep cost of comfort. The cable is heavy and microphonic... but will last forever.
- IMHO, the ER4P already sound better than the HF5 without the P->S cable... but not by a whole lot. Which leads me to my next point...
Here's my advice: try out the new MK5 Etymotic just released last month. For me, it was a very clear step up in audio quality compared to the HF series. To me, the quality of Etymotic's historical lineup ranges ER4S > ER4P/PT > ER6/i > MK5 > HF5 > EK > MC5. I'm frankly a bit surprised they're only selling for $60. Give them a spin and see if your impressions are similar, you can't go wrong for the price. They also have better, though similar, build quality to the HF series.
Overall the MK5 sound is a lot clearer and more detailed than the HF5, though the MK5 goes for a wide soundstage while the HF5 goes for an intimate in-your-face one. One big thing to note is that the MK5 have
much tighter, more present bass, compared to even the ER4 line (and no it's not boomy in any way whatsoever, it's still an Ety). It sounds quite a bit like the old ER6 with a touch less microdetail and a wider sound stage.
And just a little note, every Etymotic product I've ever heard at least sounds "fairly similar" as far as sound signature goes. In fact, they're intentionally tuned that way, to match Ety's house sound and target 'accuracy'. It's all just different levels of detail and refinement. If you like one Ety product, you'll (probably) never be completely turned off by another, as they're all alike; but you will be well-suited to eke out extra details if you can afford them.
