Empire Ears - Discussion & Impressions (Formerly EarWerkz)
- Thread starter Jack Vang
Shecky504
Today my bespoke 8 wire Thor Silver II (with 2,5 mm PSquared plug !) arrived I'd like to share some images...
Definitely an awsome pairing with the LX @ Hugo2
Edit: It's truly majestic! Electronic music sounds insanely energetic and the PSquared plug really seems to add some micro details. I'm totally blown away.....
Looks great! I have one on order too for use with my LX and DX200 How does it sound with AMP4s and 3 compared to Leonidas? My only worry is harshness in treble since the Leo is so smooth but I long for that bigger soundstage and airiness!
PinkyPowers
Reviewer: The Headphone List
If anything, Thor II is even smoother. Remember, Thor II's fame lies in it being a warmer and smoother silver cable than we're used to seeing. While the 8-wire sounds a little less warm, it somehow manages to be just as smooth on the ears.
If you are already happy with Leo, you'll be happier with this.
Sound~Patriot
agreed
Shecky504
Thanks, Pinky. Looking forward to plugging it in!
Last week I purchased a pair of demo EE Spartan IV universals from Music Sanctuary which arrived today. I'm really enjoying the improved midrange richness they offer over my Massdrop Plus, along with better articulation and more 3D soundstage. The MDP's sub-bass bump I do miss, but the tradeoff is probably worth it.
Just a question though, these nozzles are extremely short and the only silicone tips in my collection I've tried which don't slide off when removing the Spartans from my ears are Spinfits, but I find those a little boomy and would prefer to use something else. Would anyone have any advice on a means of non-permanently securing silicone tips to the nozzles more securely? I thought about wrapping thin strips of electrical tape around the area where the tips & shells meet, but it imagine the tips would still come loose eventually. Perhaps a dab of superglue might do the trick but I don't want whichever tips I choose to be on there permanently.
olddude
No glue. Try other tips such as Final Audio. When you remove the iem from your ear break the seal slowly, don't just yank it out. Rock it out slowly. I've used two different EE iem's and have no trouble when using that method. You are getting booming from silicon tips? That's a bit strange. Try changing sizes.Last week I purchased a pair of demo EE Spartan IV universals from Music Sanctuary which arrived today. I'm really enjoying the improved midrange richness they offer over my Massdrop Plus, along with better articulation and more 3D soundstage. The MDP's sub-bass bump I do miss, but the tradeoff is probably worth it.
Unfortunately I've tried Final tips along with Spiral Dots, KZ Star tips and generic silicone tips of many types and find they all get stuck in my ears. I can try rocking the earphones out more gently which is a good idea, but there will always be times when someone's trying to get my attention I'll end up yanking them out in a hurry and they'll get stuck.No glue. Try other tips such as Final Audio. When you remove the iem from your ear break the seal slowly, don't just yank it out. Rock it out slowly. I've used two different EE iem's and have no trouble when using that method. You are getting booming from silicon tips? That's a bit strange. Try changing sizes.
Spinfits I've found make the sound slightly boomy like listening through a tunnel, perhaps due to their longer than usual inner sound tube. Changing between the sizes that fit me comfortably (SS/S/M) doesn't really change this impression. Its a subtle effect but in my experience tends to make IEMs sound slightly more fatiguing so I avoid using them. Ergonomically they do work really well with short nozzle IEMs but for me are typically tips of last resort.
olddude
Except for the Phantom, I've never had any luck with Spins fitting.
Maybe try getting some thin paper, cut it up in short strips, put it around nozzles and try to get your tips over them. Different thicknesses, materials, perhaps. Or crimp gently the tips themselves and see if you can make them bind better. Or even, though I hesitate to say it, gently rough up the inside of the tips and see if that helps. What you don't want to do is mess up the nozzles.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
I once had a slightly embarrassing experience with an old pair of supra's. The seal was too good and couldn't get them out of my ears when my supervisor came over to me at work once! Caught up later and explained and he was fine, but it was a slightly "oh s*&*t" moment!
ncristia
- Mar 19, 2014
I have cut off the inner part of another tip slid it on the nozzle and worked the intended tip over it. Mostly because the tip was a narrow bore tip. Might be worth a try, we all have many extras around.Last week I purchased a pair of demo EE Spartan IV universals from Music Sanctuary which arrived today. I'm really enjoying the improved midrange richness they offer over my Massdrop Plus, along with better articulation and more 3D soundstage. The MDP's sub-bass bump I do miss, but the tradeoff is probably worth it.
deafdoorknob
klyzon
- Jan 17, 2012
Been such a long wait. Hoping empire can speed up my order for both legend and phantom haha
korvin12
- Apr 5, 2015
Wow bro, u bought both?
