NaiveSound
- Nov 8, 2015
Rattling issues are not an issue for me with regard to MAM. It's not so much rattling as it is flopping. When the membrane is the least tensioned it can be it will tend to flop around if you headband or tilt your head left and right. I don't listen at that setting as I don't like the thump-less/bass-less sound at that setting. If you do your listening sitting down, flopping or "rattling" as you say will not be an issue for you at all. I listen a8-10 hours a day at my desk and her 0 flops. I tend to listen at the impedance matched setting and 1/2 to 1/4 turn from fully open (knob all the way in).
Just to poke you a little bit...I knew you would eventually want ADEL. I tried no-ADEL yesterday by closing my MAMs all the way and I could only stand the pressure for a few minutes before I had to switch back to ADEL and was greeted by the lovely fluttering of the membrane as pressure left my canals and then the fluttering stopped and the pressure was normalized. Once you go ADEL you never go back. Also I don't perceive ADEL as lower quality (less resolution/detail), it's just different. If you want me to elaborate I can.
Please do, the more I know the better
