I'm using the Liquid Links Venon cable with my Odins. I love the look with black and gold!Any cable recommendations for the Almighty Odin? I should have mine on Wednesday and I’m curious what the Odin users are using…thanks to all that reply!
Empire Ears - Discussion & Impressions (Formerly EarWerkz)
- Thread starter Jack Vang
Tybot
Yeah...thanks a lot pal. Now we have to wait another 3 months because there's no excuse not to have that as the faceplate.bing's take on raven
I just got a custom Odin recently and was wondering about others experience with the fit. It matches the molds I got exactly, so it fits very tight and I wasn’t sure if that was normal. They sound absolutely amazing using them, I just get physical ear fatigue sooner than I expected with them
- Dec 26, 2019
Did you form your molds with your mouth open biting down on a block? If so, they’ll be tighter.I just got a custom Odin recently and was wondering about others experience with the fit. It matches the molds I got exactly, so it fits very tight and I wasn’t sure if that was normal. They sound absolutely amazing using them, I just get physical ear fatigue sooner than I expected with them
I did, so that would make a lot of sense, thank youDid you form your molds with your mouth open biting down on a block? If so, they’ll be tighter.
AboveNBeyond
You can remake them for free in the first month. My customs are slightly on a looser fit side and I can use them whole day with zero ear fatigue. If you don't use them while doing physical activities it would be worth the wait to remake them with looser fit.I just got a custom Odin recently and was wondering about others experience with the fit. It matches the molds I got exactly, so it fits very tight and I wasn’t sure if that was normal. They sound absolutely amazing using them, I just get physical ear fatigue sooner than I expected with them
If this is your first time ever wearing customs, then some tightness and fatigue is to be expected. Let your ears get used to them for a week or two. If the tightness and fatigue persists, then you can consider a refit.I just got a custom Odin recently and was wondering about others experience with the fit. It matches the molds I got exactly, so it fits very tight and I wasn’t sure if that was normal. They sound absolutely amazing using them, I just get physical ear fatigue sooner than I expected with them
Benno1988
Best to get impressions with a relaxed jaw if wanting a less tight fit?
In my experience, open/closed jaw makes less of a difference than the IEM brand’s actual trimming methods. Some keep a lot of material for a tighter fit, others trim more for a rounder, looser shape. It can even vary between models, depending on the canal length of that specific model. So, it’s best to just follow the brand’s instructions.Best to get impressions with a relaxed jaw if wanting a less tight fit?
PixelSquish
Previously known as idiotekniques
- Jul 13, 2005
Just got the Bravado Mk II - a couple reviews mentioned burn in can affect the bass, do others find that true?
Mrinfinity
I find it trueJust got the Bravado Mk II - a couple reviews mentioned burn in can affect the bass, do others find that true?
PixelSquish
- Jul 13, 2005
how much tighter did the bass get for you after how much burn in?I find it true
Mrinfinity
Only took about 10 hours, but much much tighter and I felt extension was perceptively deeper. Before burn it, bass sounded very boomy, but after I got that nice subbass rumble that I desired with controlled midbass
Total: 26 (members: 0, guests: 26)
