Third pair also on the way to A&K.Hmmm I’ve never had an issue with either EVO or Odyssey’s bone conduction drivers. What happened to your third pair were they replaced?
Waiting for an answer…
My original set of EVOs are vibrating along in both the right and left sides. No issues with mine.
Good!Hi,
Just like to thank everyone for chipping in so far about my possible Odyssey fault. Hoping someone from Empire Ears @Jack Vang (sorry Jack your the only name I know from EE) might chip in with a more technical / informed answers for us? I’m just guessing at the moment that you should be able to feel micro vibrations when I have the IEM’s in my hand and they should be felt in both sides at once?
I’m not after a witch hunt, just something I can present to whomever in the UK deals with warranty claims. I have contacted the shop I purchased them from and they have started looking into it for me.
Thanks again.
It is 110% normal to feel some vibrations in the shell as that is how it conducts the frequencies. Some are more noticeable than others due to mounting depth of W10 driver.Hi
I got this reply from the shop I purchased the Odyssey from:-
"The physical vibration itself felt from the IEM has little to do with the sound as the W10 is reverse mounted and designed to direct the vibrations to the inside of the shell and towards the listener for maximum conductivity. The reason a customer may feel a more tangible vibration is because the actual mounting surface is hand drilled and hand mounted, leaving various thicknesses, and the thinner ones may exhibit more tangible vibrations on the outside. There should only be a concern if the sound itself is not consistent. Hope this helps!"
I'm hoping someone from Empire Ears could just confirm this for me, please
Thank you.
OTL is a definitely great pairing. Eletech wise, I would look into an Iliad or Socrates 8.Looking for a new cable for the Odins. Something from Eletech likely. Ode To Laura is a bit out of my price range. The one review I could find for the Aeneid with the Odins didn't like the pairing.
Anyone using/have used Eletech cables with the Odins & enjoyed the match up ?
Any/all views appreciated.
TIA
Cheers earsOTL is a definitely great pairing. Eletech wise, I would look into an Iliad or Socrates 8.
I'd also +1 ET Illiad. If you're looking outside of ET, EA Cleo II OCTA is also another consideration and is on sale through Mother's Day, May 14 for $1279 (20% MSRP $1599).Cheers ears
EE Odin, stock PWA 1960 2w vs Cleo II octa – in this comparison the soundstage is slightly different where stock PWA adds a bit more width while Cleo II adds more depth. Tonality varies as well. Stock cable gives Odin more neutral bass quantity and brighter upper mids and treble. Cleo II gives Odin bass more texture and adds a bit more weight, and gives mids and treble smoother and more organic tonality.
Thanks heaps Cleopatra gives me something else to consider.I'd also +1 ET Illiad. If you're looking outside of ET, EA Cleo II OCTA is also another consideration and is on sale through Mother's Day, May 14 for $1279 (20% MSRP $1599).
https://twister6.com/2022/11/22/effect-audio-cleopatra-ii/
