Memorexx168
Thinking about getting lavricable for it. But all the suggestions I’ve seen so far, is to get a good copper cable. Lavricables are silver. Any thoughts on that?Odyssey stock cable,
1000000% must be upgraded.
Thoughts on the Dunu Hulk Pro as a pairing?In my experience,
Copper cable is better than silver.
But hard to find good match even though it's copper cable
(I matched genesis octa, atila, not good, perseus good)
Copper in general or copper with odyssey?In my experience,
I didn't get dunu hulk pro..~~~
The one I ordered is 2 pin. I like the swappable ends, but the price point is obviously much lower than other options people mention, so I don't know if it'd be considered too low grade with the Odyssey? I'm also a little confused as most people here seem to be recommending copper cable, and ares ii is copper, but some others recommended iliad silver cables. Is there a reason copper is preferred here?I have that cable, but I never use it. It's not very ergonomic. I got it in mmcx, so it has even less utility for me.
I have the First Times Shielding paired with the Odyssey. Provides better control of Odyssey's amazing bass!The one I ordered is 2 pin. I like the swappable ends, but the price point is obviously much lower than other options people mention, so I don't know if it'd be considered too low grade with the Odyssey? I'm also a little confused as most people here seem to be recommending copper cable, and ares ii is copper, but some others recommended iliad silver cables. Is there a reason copper is preferred here?
Bloom Audio actually recommended the Eletech Iliad, which as I understand it is a pure silver cable with gold elements. Seems to be the opposite recommendation of the stock copper, although I don't know enough about cable theory to understand why.I think it's OK except aresii stock cable even though ares2 is copper.
Ares2 is too low grade to drive odyssey.
Dean Vang, the man who designed the Odyssey recommends First Times non-shielding. I can confirm that this pairing is glorious.Bloom Audio actually recommended the Eletech Iliad, which as I understand it is a pure silver cable with gold elements. Seems to be the opposite recommendation of the stock copper, although I don't know enough about cable theory to understand why.
For about the same price, I discovered a Chinese company that makes what's actually a fabric braided 22awg pure silver cable with gold and palladium plating. Wondering if it'd be overkill or if it'd pair well with the Odyssey. There were a couple reviews that said that paired well with the Odin though so it has me wondering.
I see you own the Laura. Have you tried it with the Odyssey?Dean Vang, the man who designed the Odyssey recommends First Times non-shielding. I can confirm that this pairing is glorious.
