- Jan 15, 2015
Thanks - might be worth trying!I got Azla Earfit Short (black ones) on monday, they have pretty hard material and fit rediculously tight, even tho they have right size. I've never experienced this high audio isolation, it's almost like you're underwater. You can feel every subbass microvibration with these. Is it custom-like experience?
I'd say this is as tight as it gets, maybe aside Azla Xelastec, so if you have some other universals, try getting these tips and check. They are quite larger than usual, so get MS if you have medium sized ears.
Also, what iems have you had problems with? Universal LX shell shape is semi-custom and holds iem by itself pretty well regardless of eartips.
Honestly, I never bought expensive IEMs since I could never get a good experience. I think the only exception is the Etymotic brand (I have ER3SE, ER3XR and ER4SR) which fits and seals well, and stays in, with the default triple-flange tips. That is the reason I resorted to customs...
After my previous post, I have tried my older CIEMs (by CTM) which fit much better than the Bravados
So now, I gotta have my Bravados fit on the right CIEM fixed... Compared to the CTMs - it feels like the part that goes deep into my canals is a little thicker / wider with the Bravados, which causes discomfort and irritates the ear canals. Paying more attention - BOTH ears feel "fuller" compared to the CTM... Left is OK. kinda. Right is just too irritating.
@Jack Vang (or anyone from EE) - can you please PM me, so we can discuss outside the thread? Thanks!!
