Empire Ears - Discussion & Impressions (Formerly EarWerkz)
Jul 26, 2018 at 6:20 AM Post #15,061 of 40,613
Hello sir Mact. Yes the reference point is SP1K Cu -> Ares II -> Phantom. I'm prob gonna make this unnecessarily more complicated, but | always feel answers should have the proper nuance ; ) The first thing is that there is always going to be a unique synergy between cables and the source, besides the iem. As mentioned, the SP1K Cu is pretty warm and generally benefits from an upper treble lift, so I currently tend to prefer brighter cables. If I were to have the SP1K SS for instance, I would prob stick with the Ares II to maintain a sufficient amount of warmth. So one's source should definitely be taken into account. Sometimes I think the source synergy is more important than the iem itself.
These cables (e.g. 2.98, Thor/Leo, Eros, Ares) all have a different type of timbre, where the difference is hard to put in words since you tend to need the same descriptors. For instance, 2.98, Thor/Leo and Eros can all be described as a different variant of neutral/natural (with the SP1K Cu, the Ares II leans more predominantly to the warmer side). Even so, the Phantom paired to 2.98 is more of a 'fun' sound, mixing a light warmth with a brighter lower treble. For reference, going more in the direction of the Andro/A18 type of sound. With the Eros II, it is more of neutral with a slight touch of warmth, more similar to the Meze Empyrean or Mr. Speakers Aeon Closed we recently discussed. The EA silvers on the other hand again have a very different type of sound, which is more of an uncolored smooth sound, where both the warmth and brightness are taken out, resulting in a refined sound. Quite frankly, all of these types of sounds have something going for them, so it is hard to pick a winner, and even harder to recommend one. For example, Rick (the hifi store owner) tends to prefer the more uncolored type of sound of the Thor and Leo, since he feels it is closer to how hifi should sound, where Ares II and Eros II is closer to what I would associate with natural.
Right now I am really digging the 2.98 with the Phantom, because of its fun and stimulating sig. Its lower treble is a bit brighter than Leo and Thor, but there is a certain melodious magic going on its upper mids, where the EA silvers are a bit smoother. That being said, I don't have any of those other EA cables so my choice is not very difficult hehe. But, one of my top recommendations remains Leonidas (just regular will do), as it provides that neutral/smooth sound while maintaining the body and forwardness of its midrange compared to something like Horus (which has nicely sized vocals, but less vocal power). In addition, I found the Eros II 8-wire very intriguing so I will add that to this shortlist. Leonidas might offer greater performance, but Eros II 8-wire is perhaps one of the best pairings in terms of instrument timbre and overall signature, ahead of Leo and 2.98. Eros II 4-wire attenuates the mid-bass and does not really improve the stage dimensions, but I have the feeling 8-wire maintained a similar bass response and widened the stage. Eros II 4-wire however would be one of the best options for people that find Phantom a bit too bassy or thick, as it will reduce the mid-bass and improve the airiness, while maintaining its naturalness.
The Plus series are thick AF as is. I don't think EA makes them in 8-wire for iems, and if they did you prob wouldn't want to buy them ; )
Gawd I love thoroughness! :beerchug:
Now I just have to thoroughly convince someone an $800CAD cable is in OUR best interest....anyone know of a decent cheap Louis Vuitton knockoff?
Those are the spec for AMP1, which doesn’t use discrete components and is not as powerful as AMP8 by a long shot, or even AMP4 and 5 for that matter.
This being said, I am not surprised a desktop system will have more power (it makes sense :p) which is good for full sized cans, it probably also has more current too (or not, given it’s usually designed to drive high impedance headphones).
One thing to consider to drive the Phantom well is the output impedance on your amp (more often than not it’s not optimized for low impedance IEM), it needs to be very low (< 1ohm) as the general law here is output impedance of your source should be 1/8th of your gear (Phantom is 6ohm, so under 1 ohm of output impedance needs to be low, AMP8 on DX200 is 0.38 ohm which is good in that respect). This is important as higher output impedance will affect the signature and coherence of a multi BA setup.
First time I experienced how it can radically alter the signature is with the SE846 which at the time was one of the lowest impedance of the market (8 ohm). Low impedance IEMs or headphones are somewhat of a tricky beast, as they don’t require much power to run loud, but they require high current and low output impedance. So you might not notice your gear is not driven properly contrary to high impedance where you don’t get the required volume and drive.
Edit : I checked the HDV820’s spec, they don’t list the output impedance for headphones but... and that’s an indication, they list minimum recommended headphone impedance as 16ohm which is not unusual for a desktop system. This probably means output impedance is at least 2ohms... so not so good for best performance with the Phantom.
Driving low impedance IEMs is one area where DAPs are designed to perform, while desktop system might not (some portable AMPs are designed to drive low impedance or have a switch for them).
Brace yourself, it’s a stiff 43 ohms. I say this in the nicest way possible and knowing full-well we’re all nuts for audio.....but this dude’s nuts : )
Jul 26, 2018 at 8:37 AM Post #15,064 of 40,613
Jul 26, 2018 at 9:11 AM Post #15,065 of 40,613
i’m sorry but bro, look into campfire atlas, andromeda, and vega. shure se846 is trash and i mean that in the nicest way possible
No i am saying they sound nice on my desktop dac amp and we are discusing herw that shouldnt sound noce from desktop dac
Jul 26, 2018 at 9:28 AM Post #15,066 of 40,613
Here is tje putput impedance ots 40 ohm and it can drive iem or headphone from 16ohm to 600ohm.
Seriously i tryed my se846 from fiio x5 gen3. And it didnt sound as goood as from dac amp. I also tried idsd micro black, jds c5d labs, lg v30 is the worst sq actually lol.
So there must be something I dont get.
In all result sound was more live and imerssive on my dac amp. More basse more mid and treble but in a good way. Very musical.
So that puts mr a confusing area since you its supposed to be worse according the law of impedance.
The only hp i had ossues with was mr speaker aeon flow closed. It had 13ohm impedance it didnt sound loud enouf. Tough lcd x for example was super fine on 50%. My se846 is great at 10 o clock.
I dont know feels like my dac amp is fine.
Jul 26, 2018 at 11:07 AM Post #15,068 of 40,613
Zeus XR + WM1A + well recorded prog house = bliss (and the R setting gives you that amazing spacious soundstage if needed)
i am gonna leave here a monstrous 4-hour set by the greatest DJ in the prog house genre from 2004
@NaiveSound check this beast out
Jul 26, 2018 at 11:26 AM Post #15,069 of 40,613
Omg thank God! I ran out of stuff to listen to this saves the day. But how can someone get this in flac quality, and downloaded?
Jul 26, 2018 at 11:50 AM Post #15,070 of 40,613
only in private trackers/torrents
you can also just type (dj name + dj sets + soundcloud) in google
tons of stuff to listen to (but not downloadable i guess)
here are some top names
john digweed
sasha
chris fortier
jimmy van m
anthony pappa
dave seaman
satoshi tomiie
deep dish
sander kleinenberg
steve lawler
hernan cattaneo
everyone has his distinct style so see which one suits your preferences
here are some more nice dj mixed/comps to get you through the day (where it says cd1 means there is also cd2 - so double the pleasure)
Jul 26, 2018 at 6:34 PM Post #15,072 of 40,613
john digweed
sasha
chris fortier
jimmy van m
anthony pappa
dave seaman
satoshi tomiie
deep dish
sander kleinenberg
steve lawler
hernan cattaneo
I would add:
Ricardo Villalobos
Richie Hawtin
Sven Vath
Dubfire
Luciano
Jamie Jones
The Berghain Mixes series is pretty awesome too.
Go on Soulseek, EVERYTHING is there and most have flac versions. PM me when you do so we can swap tracks/mixes.
Back to EE discussion, I hear the 1st participants of the tour should be receiving or have received the Bravados and the ESR. Would love to hear impressions especially of the Bravado as a fun IEM and of the ESR as it compares with Andromedas and Phantoms.
Jul 26, 2018 at 9:33 PM Post #15,073 of 40,613
I would add:
Ricardo Villalobos
Richie Hawtin
Sven Vath
Dubfire
Luciano
Jamie Jones
don't mean to sound rude , but @NaiveSound asked me for late90s/early00s prog , your names are not really prog house (maybe dubfire is , but he is 1/2 of deep dish which i already mentioned) but more like techno (which i find really boring/minimal) ?
but good call on the soulseek , he will probably find tons of stuff there
Jul 27, 2018 at 5:53 AM Post #15,074 of 40,613
has anyone here listened to shure kse1200
how does it compare to the legend x (i have them) and the phantom (which i haven’t heard yet)
Jul 27, 2018 at 6:02 AM Post #15,075 of 40,613
I have, comparing with the Phantom which I own. The KSE 1200 generally was really transparent but also very digital, bordering on harshness. If the Phantom is revered for its timbre and tonality, the KSE 1200 could well be on the completely opposite end of the spectrum. There was loads of detail but at a (very huge) expense of musicality. It may be because the KSE 1200 I listened to hasn't fully burned in, or perhaps there was poor synergy with my Chord Mojo. Either way, it was not a sound that I appreciated at all.
