Effect Audio cables thread
Nov 15, 2023 at 3:06 AM Post #7,516 of 8,322
I wanted to do the same, but I was worried I would apply too much torque to the pins/connectors and would end up damaging the pins and/or ravening the IEMs themselves :frowning2:
Really the con X system is very good. And it became for me, personally, a game changer. Sort of.
Not a concern at all and far more reliable than the 2 pins and mmcx connectors themselves, the ones in the iems shells :beerchug:
There is no need at all to tighten hard. When you screw in the female connector. Really a very reliable and clever system :L3000:
If you have find "THE ONE" cable, this is it. Therefore it is a specific situation.
Nov 15, 2023 at 5:52 PM Post #7,517 of 8,322
Received a Fusion 1 cable from a friend for listening. I expected it to be a bit thicker.
Nov 16, 2023 at 2:33 PM Post #7,518 of 8,322
Okay. First impressions.
Good ergonomics. The cable is quite obedient. It is not a rope that lays the way you put it, but still the cable does not cause problems with twisting, etc. Connectors - both conX and TermX are convenient. In addition, they are made in the style of a cable, they do not look alien.
Regarding the sound. Good punchy and elastic bass. The sound preserves its integrity and does not emphasize the analytical component. The first pairing is with CA Supermoon and he adds some warmth and emotion to them that goes a good way. The stage is not very wide, but this does not cause problems.
Nov 22, 2023 at 9:24 AM Post #7,519 of 8,322
Something new for Christmas…
Ares S x Cadmus 8 Wire Limited Edition
I better start burning this in and give it a listen. I’m not sure what to expect yet. But I liked the Ares S and the Cadmus, so time to see how well they work together.
Nov 22, 2023 at 9:26 AM Post #7,520 of 8,322
Should be (very) interesting this (franken) story :beerchug:
Nov 22, 2023 at 10:32 AM Post #7,521 of 8,322
Same here... although I prefer to do my burn-in mainly by listening :)
So far, so good... and I just thought that I even heard some Christmas bells in the distance...
announcing something special coming up soon :thinking:
Nov 22, 2023 at 10:42 AM Post #7,522 of 8,322
The frankencable looks nice! How does it feel compared to their other 8w cables? And how long did it take for them to upgrade your cables once they received your 4w? Mine's still enroute to them so just curious.
Nov 22, 2023 at 11:33 AM Post #7,523 of 8,322
For me, putting it on to burn is part of the fun. It’s a bit like being part of a ceremony!
This is a demo cable that I have with me and not a commercial piece. This is also going to be a limited edition for Christmas only. There’s going to be 200 units produced. If you were going to have your cables adjusted anyway then it’s best to contact EA direct just to check on the situation.
Right now the cable is a bit stiff, but I’ve literally just taken it out of the package and so I expect it to warm up a bit when I start using it.
Edit: now that I’ve started to use it the cable actually drapes quite well. Not stiff at all.
Nov 22, 2023 at 11:51 AM Post #7,524 of 8,322
Or with body heat. :laughing:
Nov 22, 2023 at 12:16 PM Post #7,525 of 8,322
Nov 23, 2023 at 3:12 PM Post #7,526 of 8,322
You'd think its ergonomics would be right about the middle between Ares and Cadmus😂
Nov 24, 2023 at 9:43 PM Post #7,527 of 8,322
Heads up the EROS S AE is down to one unit left so if you want jump now... Snooze you lose
Nov 25, 2023 at 7:07 AM Post #7,528 of 8,322
A really nice cable, the Z Review 10th Anniversary Cadmus 8W...
Nov 25, 2023 at 2:46 PM Post #7,530 of 8,322
Color scheme.
