Personally I love the 8-wires for listening at home and while I work, but I never use them for on-the-go. I have actually gone so far that I now often use my Final E2000 for on the go and am thinking about getting an extra thin cable for my Ei.3 to get an optimal setup for when I am out and about. I still have a thin cable from EA, but it needs to be re-terminated because it keeps cutting out. Had a friend fix it before, but I managed to break it again soon after.After going from the Janus D to an Ares II it really puts into perspective the sheer size of the Janus, that cable is a monster. I'm actually really liking the 4 wire set up again. It makes my CIEMs feel like they're non-existent whereas the Janus would weigh them down a bit and did cause some slight discomfort.
Now I'm unsure if I should stick with my regular Ares II or upgrade to the 8 wire? I know the Janus D is thicker than other 8 wire cables due to the 24 AWG wire but it does have me second guessing.
Thoughts?
Anyway, this all has sort of got me to the point where I want to get specific setups for either different music types, or type of use. My Ei.3 with a thin cable for on-the-go (currently Ares II or Lionheart 4W) or alternatively with the Ares II 8-wire for gaming (it is glorious!), my Saturn with a silver cable for moar bass, and my Phantom with Ares II/Eros II 8-wire for outright sound quality.
Not sure if this helps you, but I guess it is a good excuse to own multiple options.
