Storytime
- Dec 17, 2015
There aren't much options.
1) all black instead of silver top and bottom
2) P&G pot, much nicer than stock.
3) no tube upgrades, you get the standard ones. For power it doesn't matter as there is nothing else. For rectifier same thing, well there is the EY500A but it doesn't make a difference. For the driver you get the stock Tung Sol which is worthless. Buy yourself some RCA 5691, Mullard ECC35, Brimar CV 1985, Sophia Electric Premium 6SL7 and/or Tung-Sol 6SU7GTY.
4) my first Zana was balanced but that was the only one ever produced. I don't think Craig is gonna do that again and it would cost a fair bit more.
Regarding upgrades, I got the P&G volume pot (and have been quite happy with it), but I recently read that the folks at Eddie Current do NOT recommend most folks to opt for it. You might want to contact them directly and see what they advise given your particular system profile.
One additional upgrade to consider is an upgraded fuse. I purchased a Synergistic Research fuse and had it shipped directly to Eddie Current during my ZDS build process, and Craig installed it for me. I ordered the Red Quantum Fuse, but I gather that now they have a Black Quantum Fuse that's a bit better. According to my notes, the specs you want are: small 5x20mm (0.75"), Slow (T), 4A. But be sure to check with Craig first, as my notes may be off.
Hope this helps.
