“The balanced High voltage/high amperage AMP3 for the DX200 now available!
Average Play Time: 7.5 hours.
The play time varies with different sample rate/bit rates, and headphone/IEM loads.
Features:
1. +/-8V voltage swing, equal to 32V voltage swing when compared to single ended. This significantly improves the dynamics and headroom.
2. Patented balanced amplification circuit, that retains all the benefits of a balanced design, such as higher output voltage and lower crosstalk. At the same time, our Patented design has even harmonics that keeps the sound full and musical. *
3. Topology utilizing voltage feedback and current feedback, utilizing the benefits of both types of feedback.
4. OPAMP+BUF architecture, optimized for both high voltage demand and high output current demand monitors.
* With the traditional balanced amplification circuit design, there is a positive signal and a negative signal. They together reduce the harmonics, including both of the odd harmonics and even harmonics. On this amplification design, even though sound is more powerful, the sound is often flat and less musical, as even harmonics are reduced. On the iBasso balanced amplification design, we successfully reduce the odd harmonic, while retaining the even harmonics, thus keeping the sound full and as musical as single ended but with the added benefits of a balanced signal.“
“The AMP4 balanced with a 4.4mm TRRRS socket. High voltage and high current with and extremely low output impedance at approximately .3 ohms. Full bodied with a frequency response from 10Hz to 45KHz -0.5dB. “
“AMP5 coming your way soon. High current and voltage with excellent frequency extension. A sweet top end with dynamics and headroom for most any headphone or IEM. Single ended in 3.5 TRS.”
Edit: added more information from iBasso on Facebook(Quotes).
I am also interested in the differences between the amps.
What is the difference of the internals?
Their intended functions, If any.
(Aside from the jacks differences)
I have a couple of the amps and am still listening and comparing.
1. Seems to be a reference type sound.
2. Adds a bit more sub bass/ bass rumble.Fuller sound. SE.
3. Is a balanced version of number two.
4. I dont have.
5. I will listen to tomorrow.
