I don't read Japanese, do you know what material is used to make this cable?
Use google chrome. Right click translate yo english. It is silver plated OFC.
By the way, that translation of "nippon dic*"
Holy cow...the guy on Amazon has it for $234.83!
Yeah! The link was sent by someone in this thread is much cheaper than the one on Amazon (($100 vs $235!)
Can post a link to the cable?Triton Audio also makes a nice converter from 2.5mm to 4.4mm. Good cables for decent money
deleted irrelevanti can't seem to enter the loader or flash mode on my ibasso?i turn it off , hold pla, connect it to the pc and it just shows charging after 5 seconds..[/QUOTE
???i want to flash lurker fw so i need to access the recovery mode, by following the instructions it doesnt workScroll down from top with finger. Menu says charging scroll further and choose view SD card.
This is implemented in hardware (SoC), not in the firmware. So, if it does not work, it should be hardware problem, with USB cable, socket, controller inside your DX200...i turn it off , hold pla, connect it to the pc and it just shows charging after 5 seconds
What do you mean? Its charging, I can see both internal and external sd cards. So usb is fine, what would be wrongThis is implemented in hardware (SoC), not in the firmware. So, if it does not work, it should be hardware problem, with USB cable, socket, controller inside your DX200...
You have the flash utility tool launched/running when holding play button and plugging cable in correct?
Yes correct. Only issue is I didn't have to install the provided driver as windows installed it and recognized it as dx200
