DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-14275287
Post #13,756 of 21,865
jasonho
Singapore
Singapore
And I thought $50 was expensive for an adapter!! Although it looks really nice and very functional. I just started using the Ibasso CA02 and it's awkwardly long.
yup, I have CA02 and also tried other similar adapter (like Effect Audio), and I also find them awkwardly long. Thats the reason I bought this and keep CA02 for desktop use :)
Reactions: pali
post-14276667
Post #13,757 of 21,865
SQ13
Hi,
I just encountered a weird issue using Lurker new firmware. I have been using Mango OS most of the time but decided to switch to Android mango player today. I have no problem playing flac 16/44, 24/192 or wav 24/352. However, when I played DSD or flac 24/352, there is no sound even when the music is playing. All these works in mango OS. I tried factory reset and the same problem exist. Did anyone encounter this issue?
I reset and reinstalled the latest ibasso firmware, retested the Android mango player it is working fine. I will try Lurker firmware again later.
post-14276706
Post #13,758 of 21,865
jasonho
Singapore
Singapore
Hi,
I had emailed lurker and he has already fixed this in a later version
post-14276798
Post #13,759 of 21,865
Signal2Noise
Wherever the music takes me
... or flac 24/352, there is no sound even when the music is playing. ....
Lol. The bats in the area hear it just fine :laughing:
Reactions: mrmoto050
post-14276802
Post #13,760 of 21,865
Lurker0
Moscow, Russia
Moscow, Russia
I've PMed you links to the new build.
post-14277553
Post #13,762 of 21,865
swesko
No but or vas weak wifi range i get full bars on all my equipment at home yet the ibasso only gets 4 bars at best
post-14277562
Post #13,763 of 21,865
Signal2Noise
Does dx200 have bad wifi interference?? When using Tidal as streaming over wifi do you hear static or any other noise at all?
There will be "static" from Tidal soon enough. :wink:
post-14277584
Post #13,764 of 21,865
fuhransahis
NY
NY
You need a 5G WiFi connection .
Reactions: W4lt
post-14278397
Post #13,765 of 21,865
Lurker0
Moscow, Russia
Moscow, Russia
Sorry, but I had to release 2.9.209-L1. The changes are:
  • Problem resolved: Mango can't play DSD in 2.9.209-L0.
  • Problem reported as resolved: those "cracks and pops" while track changing in Tidal, Spotify etc. Same solution as in 2.9.198-L1 back again.
post-14278703
Post #13,766 of 21,865
Lurker0
Moscow, Russia
Moscow, Russia
By the way...
This time I even performed some tests with Bluetooth headphones, to be sure BT audio works correctly.
Mango Player plays only 16/44.
UAPP and Neutron play up to 24/192 via their direct drivers!
Hiby Music, being used without USB Audio, converts all to 16/44, and, as such, plays just fine all supported formats, including DSD.
So, if, for a reason, you want to use BT audio, just use Hiby, Neutron or UAPP, to play everything you have. Of course, it is about usability only, and nothing regarding quality :)
Reactions: xnuthecaveman
post-14279071
Post #13,767 of 21,865
HungryPanda
Kent, UK
Kent, UK
I love rhe neutrality of this DX200. My music sounds outstanding. Some earbuds don't cut the mustard now but I have other daps for them
post-14279104
Post #13,768 of 21,865
KEV G
LONDON
LONDON
Glad your enjoying your 200, I’m listening to mine at the moment with Amp4s + HD660s and loving it :ksc75smile:
post-14279194
Post #13,769 of 21,865
SQ13
Thanks, I will test it.
post-14279306
Post #13,770 of 21,865
pali
USA
USA
I don’t use IEMS but hissing with amp modules are never there for me.
If you like speedy bass and tightest energy, nothing beat Amp3
Musicality ? Nothing beat amp4S
Between Amp3 and Amp4s = Amp4 LOL
Tried AMP3 today because of your post. Have to say that I'm liking the sound. Still airy and clean like AMP1 but with more musicality.
Somewhere in between AMP3 and AMP4s sounds very promising. Now, just have to find one. >.<
Personally Amp4s sounds incoherent to me. Instrument placement doesn't sound right. I'm surprised that I am actually preferring Amp 1 and 5. Just me though.
I totally understand what you mean - sometimes it sounds like I'm in a cave. Hoping that burn in solves this 'problem' but so far, AMP4s is still the one that makes my feet tap.
Reactions: natemact
Users Who Are Viewing This Thread (Users: 1, Guests: 4)
