I have been waiting awhile for the 4, hope its equal or better then the original minus the connection issue , that would be
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
Thanks artpiggo!
Not sure how to use it in my chain...
I currently have WD HDD -> OTG cable -> DX200. This means I can’t charge simultaneously while playing music.
Would I use the iDefender like this:
WD HDD -> OTG cable -> iDefender** -> USB-A female to USB-C male adapter -> DX200
** with a power source attached to the side of the iDefender?
Would the OTG function be maintained through this chain?
Otherwise I was thinking of using a hub like this:
https://www.amazon.com/gp/aw/d/B076ZLLJ8M/ref=ox_sc_act_image_3?smid=A111Y7QHDCGSHK&psc=1
Could this hub work if the iDefender doesn’t?
Thanks!
WD HDD -> iDefender** -> USB-A female to USB-C male adapter -> DX200
____________^ Powebank
The link of usb hub is for macbook. cannot apply to DX200. iDefender is the only option to have both data playback + charging.
Lurker0
It's just a USB hub. Why do you think there are USB hubs for Apple products only?The link of usb hub is for macbook. cannot apply to DX200
Because I mostly see the picture of macbook connect with this hub when they are advertising the product. So I thought it is for macbook.
meomap
Hi,
Anyone has shipping confirmation from DHL yet to U.S. if bought it yesterday afternoon?
jockwong
- Jun 8, 2015
Thanks artpiggo and Lurker!
Artpiggo, do you use that flow chart you show? That is, the iDefender can access the data from the HDD (without the need for an OTG cable), pass the data to DX200, and also at the same time charge the DX200 (if a power bank/source is attached to the side of the iDefender)?
Thanks again!
Hi all , yes think 4s is sold out. Ibasso just refunded my payment....
Lucif6r6th
Don't worry about it. Zeppelin in Singapore might get some stockHi all , yes think 4s is sold out. Ibasso just refunded my payment....
I've been wondering this as well. If resampled I was going to use UAPP, but I guess it's currently got a little bug with a near deafening outcome....at least it wants to make you deaf bit perfectlyIs Tidal apk bitperfect or resampled through Android mixer?
Tennessee
- Sep 16, 2014
I'm using UAPP with tidal everyday with no problems.I've been wondering this as well. If resampled I was going to use UAPP, but I guess it's currently got a little bug with a near deafening outcome....at least it wants to make you deaf bit perfectly
@Tennessee Thx a bunch. Wondering if you have compared Tidal offline to UAPP Tidal streaming?
Shecky504
If you're referring to the audio output not working in bit perfect mode with the HiRes driver enabled, I reached out to the developer about it and he has a fix in place. *Edit - Looks like he already updated the app yesterday. I haven't tried that version yet.I've been wondering this as well. If resampled I was going to use UAPP, but I guess it's currently got a little bug with a near deafening outcome....at least it wants to make you deaf bit perfectly
Lurker0
Version 4.2.0 is OK, but 4.2.1 and 4.2.2 are broken on DX200. I've already notified the developers.I'm using UAPP with tidal everyday with no problems.
Tennessee
- Sep 16, 2014
Tidal offline is inferior to UAPP in terms of SQ.@Tennessee Thx a bunch. Wondering if you have compared Tidal offline to UAPP Tidal streaming?
Total: 18 (members: 0, guests: 18)
