Womaz
Its the one you get with Sky Broadband in the UK
Amp 4 info at carvelink facebook
https://m.facebook.com/carvelink/posts/733486690194913
Google translate at your will.
In sum, they will produce only 250 pieces. Sound is better than amp3 in high and low frequency. (V shape sig?)
After looking on their page, Sky doesn't list which routers they use.Its the one you get with Sky Broadband in the UK
I wonder if this will be worth getting if you don't even have a pentaconn connector. I know there are 2.5mm to 4.4mm adapters, but at this point, I would be buying it only for the change in amp sound signature.
Then again the new HD660S will come with a pentaconn cable, and as far as I'm aware, there are no 4.4mm to 2.5mm adapters (not possible I guess).
It is a setting for your Internet Router usually 2.4GB or 5GB, some of them are dual channel.I am non technical I am afraid so I have no idea, also no idea how to find out or to set it at this
Thank you for your response.Hi
for sure I prefer ARM2 vs dx200+AMP1 in single ended. ARM2 sounds has more body and the difference is, for me, specifcally on the percussions credibility. the punch (that is something you can't "solve" through equalizer...) is definitively more real by ARM2 reproduction. To understand what I mean you need to have both player in your hands and listen them with the same songs. In general the soundstage of dx200 is wider than ARM2 but sometimes too much larger. I mean ARM2 soundstage is enough to be present but not too much to be not beliavable.
For example the DSD64 of Sultain of Swing in live: if you hear it through ARM2 you can concentrate on the Knopfler guitar that drive you along all the song. While in dx200 you have all micro details too much "present" so Knopler guitar appears less clear and the result is less musical.
Using dx200 in balanced mode, in particular through AMP3, the comparison with ARM2 changes and the improvement given by a better channels separation gives depth to the dx200 big amount of details, returning the right space to each instruments and obtaining that sound "body" that in my opinion misses in single ended AMP1.
It's used in conjunction with USB Pro driver so it can play Hi Rez files at recorded Bit Rates^
Lurker0's custom firmware includes an optimized version of Hiby, although I do not know really what it entails.
Usually you can log into your router and it will tell you which one you can use or both.
No line out? That's a deal breaker for me.Via iBasso Twitter
You shouldn't have any issues. I download and listen to HiFi content offline all the time. It plays just fine,
