DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-13806267
Post #9,631 of 21,843
jerick70
Utah, USA
Utah, USA
I'm too lazy to look back through 600+ pages. Wondering if anyone knows when amp4 will be available. I would love to audition this player, but everything I have now is 4.4mm and I don't want to buy cables or adapter to do so.
I don't think it's been announced yet. If I remember it will be announced in the next week or so.
Reactions: TenderTendon
post-13806271
Post #9,632 of 21,843
TenderTendon
post-13806311
Post #9,633 of 21,843
Lurker0
Moscow, Russia
Moscow, Russia
@Lurker0 what does switching the XMOS chip to DSD/ USB DAC mode actually do?
In this mode, XMOS chip is connected to an internal USB connector of the SoC. When it happens, ALSA (Linux level audio driver) installs its driver, and XMOS chip becomes accessible via it, as a second sound card (3rd actually: the 2nd is S/PDIF output). This is how MangoPlayer uses it to play DSD - via ALSA.
Neutron, with Generic drivers, uses Android path (modified by iBasso) for playback. My modified tinyalsa level redirects Android sound system to this second sound card. This path is longer: Android AudioTrack, Android media server, ALSA, kernel level driver.
But when Neutron (or other apps) uses USB interface directly, the overall sound path is much shorter, no Android/ALSA stuff involved at all. Only kernel level USB driver is involved. This may lead to a slightly different sound signature, though the audio stream goes unaffected (bit perfect) in all the cases.
Reactions: cbeaumont001
post-13806334
Post #9,634 of 21,843
ExpatinJapan
Hell
Hell
post-13806395
Post #9,636 of 21,843
TheUbiquitous
I wish for an amp like AMP3 (or 4) but with single ended line out, it could be AMP3.5 or whatever.
What do you think?
post-13806400
Post #9,637 of 21,843
jerick70
Utah, USA
Utah, USA
What do you think?
AMP1 is already like that. It just doesn't sound as good as AMP3. I'm with you on the SE out. I miss it all the time with my AMP3.
post-13806515
Post #9,638 of 21,843
Frankie Styles
Melbourne
Melbourne
Has anyone had issues connecting their DX200 to their PC/MAC?
When I connect I don't get the prompt on the DX200 to enable USB File Transfers (MTP). It remains on charging only and the device refuses to show up in the file manager.
The only way I can seem to make this work at all is to enable Developer mode on the device and play around with USB debugging. And that is also quite intermittent.
Is this a common issue among android devices or is it just mine?
post-13806522
Post #9,639 of 21,843
jasonho
Singapore
Singapore
Same here too, using a macbook. same issue
post-13806532
Post #9,640 of 21,843
Womaz
Newcastle , England
Newcastle , England
I previously had issues with the beginning of each song (approx .5 seconds into the song) stutters when offline files were stored on SD card. Storing offline files on internal DX200 storage resolved the problem. Perhaps the latest version of Tidal has resolved this issue?
I will try this. This is the first time I have had to update my Tidal as I am a fairly new IBasso owner. I am presuming I have to delete my Tidal app and then install the new version? Hoping I dont lose any playlists or saved albums etc
I am just using the IBasso software, none of the others or other players.
post-13806636
Post #9,641 of 21,843
Layman1
The Big Smoke
The Big Smoke
At CanJam London this year we had a demo provisionally called AMP4. It was effectively something analogous to the AMP3, but single-ended (both headphone out and line out).
Now iBasso are about to release a different AMP4, but I've heard it said that the demo unit from CanJam will be released as the AMP5; a high-voltage single-ended amp unit, probably with a line-out included.
However, as can be noticed from reading back through the threads, whilst speculation is fun, we simply won't know anything for sure until it's basically ready to be released.
And I think that's a good way to be! People (myself included), are excited for details and release dates, but this way lets iBasso focus on getting it right first time (like they did recently with the AMP3 for example) :)
Reactions: jerick70 and KEV G
post-13806976
Post #9,642 of 21,843
mrmoto050
Babylon
Babylon
What do you think?
AMP2 is SE out only with Line out 3.5
post-13806980
Post #9,643 of 21,843
mrmoto050
Babylon
Babylon
When you plug it into USB port drop down top menu on device (DX200) it will then give you options. File Trasfer, Charge Only, OTG .. etc.
post-13807007
Post #9,645 of 21,843
ExpatinJapan
Hell
Hell
Thats what it should do. It doesn't prompt me with the list of options. It just says 'Charging'. When you pull the top drop down menu no options are there.
try a different usb cable . Worked for me.
Reactions: Frankie Styles
Users Who Are Viewing This Thread (Users: 1, Guests: 4)
