Will DX200 decode DSD256 natively and bring OLED screen?
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
- Feb 11, 2008
What did bass boost ever do to you... just an innocent little switch trying to make its way in the world
It's not the switch that bothers me - it's the potential of unnecessary components on the circuitboard, polluting the purity of the circuitry and the signal, and/or complicating the efficiency of the firmware.
Totally unnecessary (and bad for your hearing, especially if you listen with sealed IEMs/CIEMs, as increased bass leads to increased excursion of the eardrum, and increased physical stimulation of the cilia in the cochlea).
At least we die happy, bleeding from our ears
m0nster
- Jun 9, 2015
Darn, now I have to wait too.
Any news? Come on, we all know the guys over at iBasso work like crazy on this. Someone could at least tell us what exactly they are working on
cjs001
- Jul 9, 2014
I'm pretty sure there is probably some form of NDA in their employment contract
Tell you what. The market is becoming quite congested with DAP's lately. What the hell is going on. I mean it's a small market considering most people use their phones these days and there are only so many people who want the latest and greatest. Lot's of new gotta get on the hype train scenarios whilst perfectly fine DAP's released not so long ago are no longer popular yet they have the same primary features ie the ability to reproduce music satisfactorily.
It's crazy!!
It's crazy!!
m0nster
- Jun 9, 2015
It's crazy!!
Well, mate, it's a crazy worl we're living in.
But your critique is pretty much on point. It's something I should really learn - enjoy what I allready have instead of desperately waiting for what I could still get..
- Oct 6, 2013
It's crazy!!
And that is a reason why Android DAP releases getting so much attention (DX200, X7, DP-X1, i5) - many people like the convenience of combining the best of a standalone DAP with a smartphone wireless/streaming functionality. Sure, smartphones can play music, but can they drive demanding headphones? They can implement the best DAC, but do they have room to partition properly digital vs analog circuit while keeping noise coupling under control? They are super thin, which means not enough room for quality power filtering capacitors or implementing a proper analog amp section. And just think how fast your phone battery drains with 3G/4G wireless radio on, and with a constant music streaming you will drain the battery even faster. Smartphone solution - OTG usb dac, but that means strapping another piece of equipment to the back of your phone, making it less pocketable/portable. And if you are dealing with a small usb DAC without battery - you will drain your phone's battery faster, while with a bigger usb DAC with a battery built-in - you are adding even more bulk and rubber bands which are covering your touch screen.
There are plenty of pros and cons. In my opinion, Android DAP still make a lot of sense if they combine the best of the summit-fi DAP and the best of your smartphone (minus the wireless radio). And I also think small dedicated DAPs also make a lot of sense where you get a basic touch screen functionality and a long battery life (plenue D got it right, but I heard from others the sound quality is meh). Personally, I would have loved in addition to DX200 to see something like DX30 at half the size of DX80 and at least double the battery life
Raketen
- Apr 5, 2010
Yeah, I'm all for Android based DAP's but they are not really the full on Android experience. A modded version unless I'm mistaken by the DAP manufacturer and at the mercy of their firmware upgrades as opposed to full on OTA updates. In addition they are still a little laggy compared to the CPU's and amount of RAM found in smartphones.
As for USB OTG I'm using a dedicated Galaxy S3 so the only negative for me is the stack. After the mobile plan on each Phone expires it will be relegated to a source for the DAC/AMP I have at the time.
T.R.A.N.C.E.
- Mar 24, 2010
DX90 is old news, daps have since advanced in their circuit design, now days daps use a CPLD for audio processing instead of the CPU which has to run the OS, this improves audio quality by no small amount, all newer daps have progressed in this direction. HM801, DX90, X5, AK120, etc, that general era of daps relied on the CPU for everything. The next gen of daps QA360, AK240, N6, X5ii, DX80, M2, QP1R, etc, etc, all use an intermediary chip for audio processing. If you just want a dap that works well then DX90 is fine, but if you don't want outdated tech, then skip dx90.
edit: above edited their comment and now my comment is no longer relevant, heh.
wyvernone
- May 19, 2006
Anyone want to experience an Android smarthphone with the ES9028 DAC you can try the Vivo X6Plus now. Too bad it's quite bulky at 5.7 inch and it's also a shame any smartphone being used as a DAP goes out-of-date more quickly than a non-smartphone DAP, plus you don't look like an audiophile using a smartphone player
As an aside I hope the DX200 is priced in the right range perhaps double the price of the the DX80? Anywhere higher than that and I am leaning toward an AK300 at this time already.
Kerouac
OK then...because the waiting (for DX200) takes so long, I decided to treat myself on a used DX100 in the meantime...
...and I must say that I'm very impressed with its sq (I prefer it over DX90) so far
Now the waiting continues (while listening)
Raketen
- Apr 5, 2010
DX200 actually going to be just two DX100's glued together, for balanced out you plug one ear into each and hit play at the same time.
- Feb 11, 2008
I don't think I could handle the awfulness of the DX100s firmware multiplied by 2!
Total: 7 (members: 0, guests: 7)
