- Oct 6, 2013
I doubt anybody that has heard and compared a lot of gears, would argue that the 901S is among the best daps - single ended. Yet it improves significantly balanced. The same is true of the Plenue S.
The precision in soundstage, the more holographic and 3D imaging, is not 'a gimmick'. I let my friends that have zero audiophile experience listen to the difference, and they are mindblown. It's that obvious and easy to hear. I can't speak for the AK daps of course.
You have to try Lotoo PAW Gold. 3.5mm SE only, but soundstage is more expanded than balanced outputs of AK120ii, N5, PAW 5k, Opus#1, and L3. The L3 balanced comes very close, but still can't reach the same level of width and transparency. Never tried HM901S though. Also heard from a trusted source that PS sounds very close to LPG.
Regarding issues with 2.5mm trrs, yes I have an issue with AK120ii after a year of use, and also heard quite a few negative comments about DP-X1, but all of my other 2.5mm TRRS DAPs are perfectly fine which suggests not the problem with a port but rather with how manufacturer solders and secures it to pwb.
