DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
1434 1435 1436 1437 1438 1439 1440 1441 1442 1443
1445 1446 1447
  1. JacentyEsz
    I updated the player to the latest software version and my DX200 turned into a stove. After half an hour of listening, I had to turn it off because it is so hot that I'm afraid that something will break.
  2. jamato8 Contributor
    Did you try a factory reset? Odd that it is doing that.
  3. duyanh43
    Update this FW is a little buggy, as I already installed Lurker0 from previous FW, but factory reset solved the problem. Works smoothly now
  4. JacentyEsz
    i did and after that it is even worse in both mode, android and mango.
  5. jamato8 Contributor
    I would try the prior fw then. Or, use the Android Tool for 8.1 like the beta version of 8.1 on the ibasso download site and update again to the latest firmware.
  6. strawberry
    I also find a similar issue in v1.09 with the heat and the battery drain much faster.
    I also hear a hissing sound in the left channel for 1-2 minutes then it went away.
    I want to reverse to the previous version v1.07 by putting the v1.07 zip file into the sd card method and using the updater.
    the system returned the following message: " cannot install this package over newer build". Installation aborted
    So how can I reverse to an older version?
    Any help is appreciated
  7. strawberry
    Further update
    Previously, i only heard the hiss in the left channel for one to two minutes then it die dowm.
    Now the hiss persists in the left channel.
    I did a several factory reset and it is the same.
    I even switch the amp to amp 4 but the left channel still hears the hiss.
    I think it is a mother board problem noow
  8. Paul - iBasso
    I am sorry this is happening. You can go to our site and reinstall the Beta of 8.1 using the Android Tool that is down the Download page a number of lines. This has to be done on a PC and the instructions are in the download. You also have to install the USB/DAC driver. You can then update with the SD card to the previous firmware.
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
  9. iranonfr
    Almost same issue here, thought it was my amp8 broken until i test with amp3.
    But it happen only under Mangos, no hiss on left channel under Android.
  10. strawberry
    Newest update
    I only tested it in Mango mode but not in Android.
    The hiss in the left channel persisted even I stopped the playback. It only disappeared after I switch off DX200.
    I followed Paul's advice to switch back to version Beta of 8.1 using the Android Tool then update it to version v1.07.
    The hiss disappeared.:smile_phones:
    Now I can listen to my music again. hope no permanent damage was done.
    in my opinion, the latest firmeware version v1.09 might have put up a higher voltage/current to the DX200 system. Due to some subtle difference in the circuit components, some might have overload and hear the hiss and some not.
    I forgot to say that my amp is Amp 1 (MOD) made by ibasso in late 2018 before the DX220. I also have a original Amp 4 bought secondhand. I am looking forward to the Amp 8-Ex Fan edition from Ibasso. Hope it arrive before Christmas.
    Happy listening:dt880smile::ksc75smile::o2smile:
  11. iranonfr
    good to know, i will do the same sooner :thumbsup:
  12. Whitigir
    1Tb MicroSD is 299 on Prime ! I just grabbed mine! WooooHhhhh
  13. jamato8 Contributor
    Please stop posting this nonsense! Damn, now I spent another 300 dollars. Damn.
    Whitigir and DaYooper like this.
  14. DaYooper
    I bought one a couple weeks ago for $329. It's in my DX220. I found it easy to end up with corrupt files and had to reload it with my 775G library. After screwing up the scan process did a reset on the dap and started over. One must learn to keep hands off until process is done! First scan in android, then Mango. All good now. until the ever growing library outgrows the chip.
  15. DaYooper
    Ya, me too.
1445 1446 1447
