Dobrescu George
Reviewer: AudiophileHeaven
Hi, may I know if it’s normal that my dx220 drain from 75% to 49% after listening for an hour? Using d it with amp1v2 with medium gain.
Ugh, that's a bit much
Were you at absolute maximum volume?
It should drain slower, I get about 2 hours from 100% to about 65 % - 70 % , with AMP 7
You can always hope for a software glitch like mine had, listened to Beyerdynamic T90 on volume 10! But I did a factory reset for fear of breaking either my ears or Amp9
That would be pretty funny, but it just doesn't drive Sundara, which are my main portables
I need more volume. It isn't painfully quiet, just a bit quieter than I typically listen to, say, if I listen at 110 dB, AMP 9 with Sundara stops at about 100 - 103 dB
(lets not turn this into a volume convo, I know what I'm doing )
