DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-15086355
Post #21,496 of 21,843
highfell
I have noticed that 24 bit/ 94kHz tracks seem to sound really smooth with the DX200 and AMP9.
I would like to try some upsampling software which also ideally has some noise shaping maybe mirroring (to any extent) what Rob Watts has done at Chord.
What I am looking for is an offline programme that can covert my Flac files from 16 bit/44.1 khz to 24/94, so I can save these newly converted files onto my SDcards.
It would need to run on a Mac not Windows.
Thanks
post-15098856
Post #21,497 of 21,843
truenobzr
Hong Kong
Hong Kong
Does anyone has auto shutdown issue with AMP8 under latest firmware and lurker addon?? System auto shutdown under 5min after reboot, I can’t listen even one song... Seems don’t have such problem with AMP5 and AMP9.
post-15099268
Post #21,498 of 21,843
Pictograms
Canada
Canada
Have you tried a factory reset and re install lurker? Seems to sort out lots of problems... but I haven’t personally experienced this problem
post-15099325
Post #21,499 of 21,843
ExpatinJapan
Hell
Hell
‘Ello ello! Wots all this about then, eh?!’
post-15100121
Post #21,500 of 21,843
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
post-15100909
Post #21,501 of 21,843
Lurker0
Moscow, Russia
Moscow, Russia
From the picture, the first Android device ever that adjusts lock screen theme to match casing color. Still in beta.
post-15103910
Post #21,502 of 21,843
Pictograms
Canada
Canada
I am having a strange bug with the dx200 and amp 9... I am currently using campfire audio cascade at volume 2! Waaaay to loud to listen any higher. I have never got-swapped amps.
I’ll be doing a factory reset tonight.
Yesterday the volume would not change from 80 even though the indicator would say different levels numbers. So I turned off the dx200 unplugged and replugged amp9 and that fixed it until just now.
post-15103930
Post #21,503 of 21,843
jamato8
I would do use the Android Tool and and .img firmware to reload the firmware on the DX200 and then do an update to the latest fw to clear any bugs.
Or try reloading the newest firmware.
post-15103969
Post #21,504 of 21,843
Pictograms
Canada
Canada
Thanks! That’s my plan, it just depends on finding my computer... haven’t used it in weeks.
I was more just putting the bug out there, I was wondering if anyone having issues with Amp9 being underpowered for iems we’re suffering from something similar
post-15110104
Post #21,505 of 21,843
Matpar
Torino
Torino
Amp9 on its way, can't wait to plug It to my dx200 :)
Let's see how does It performs.. After ages of 2.5 balanced, I am really curious :)
post-15110127
Post #21,506 of 21,843
singleended5863
You won’t regret amp9 sounding. I switch back and forth between the DX200TI and DX220 amp9 has exceptionally excellent on both. However, you would let it break in throughly you wouldn’t be disappointing. Happy listening.
post-15110140
Post #21,507 of 21,843
Matpar
Torino
Torino
I have a pair of Audeze isine 20 on test from a friend.. I believe they might reveal to be a good match in this setup.. hopefully :wink:
Btw, in balanced mode with amp3 they Just don't work. :frowning2:
post-15111276
Post #21,508 of 21,843
Dobrescu George
Bucharest, Romania
Bucharest, Romania
Age
25
Website
I agree, you can't regret AMP9 in terms of sound, it is sublime. The only thing I can wish, is that AMP 9 had more power :)
Reactions: PaganDL
post-15111313
Post #21,509 of 21,843
Snowball0906
Malaysia
Malaysia
Hi, may I know if it’s normal that my dx220 drain from 75% to 49% after listening for an hour? Using d it with amp1v2 with medium gain.
post-15111320
Post #21,510 of 21,843
Pictograms
Canada
Canada
You can always hope for a software glitch like mine had, listened to Beyerdynamic T90 on volume 10! But I did a factory reset for fear of breaking either my ears or Amp9
Reactions: Dobrescu George
Users Who Are Viewing This Thread (Users: 1, Guests: 6)
