DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-15130256
Post #21,541 of 21,843
Rayzilla
From Toronto to Hong Kong (now)
Fixed.
*insert upvote via like button
Unfortunately the problem continued so I will order the battery from Paul tonight and hope that we'll solve the problem.
While I'm at it, is anyone here familiar with those ultra portable daps iike M5, M0, and ap8? I might pick up one of them for the gym or for running. I need some incentive to exercise.
post-15130272
Post #21,542 of 21,843
ExpatinJapan
Hell
Hell
Good idea.
And good luck.
I have M0 And AP80. Both good little daps.
M0 is a bit warmer and the Ap80 more towards neutral.
The m0 Is slightly smaller.
I have not tried the FiiO M5.
post-15130307
Post #21,543 of 21,843
Pictograms
Canada
Canada
I have a fiio btr1k for the gym. When running and such I don’t really care about the quality but I do like the connection to my phone in case of a call.
I feel anything larger than a iPod classic gets in the way... I am wondering if I would notice a difference between the dx200 and btr while exercising.... hmmmm...
Reactions: Rayzilla
post-15130918
Post #21,544 of 21,843
Wong Jawi
Indonesia
Indonesia
dx200 temperatur becomes hot when playing Tidal MQA.
Gain position is low at volume 70. Is it normal ?
doesn't occur if playing Tidal hifi. Anyone have the same experience?
post-15174814
Post #21,545 of 21,843
davidmolliere
Paris, France
Paris, France
Website
iem.reviews
Gain position is low at volume 70. Is it normal ? Doesn't occur if playing Tidal hifi. Anyone have the same experience?
Didn’t notice this... not really significantly anyway, or not more than the same thing with Mango between CD or HiRes quality it does take more processing power for sure.
post-15183550
Post #21,547 of 21,843
reddington
Recently got one. Looking to get an Amp8 or 9 for my Andromedas. Any inputs on which one would be better?
post-15183585
Post #21,548 of 21,843
singleended5863
To me amp9 has more reference sound but it has 3.5 SE for your Andromeda whereas amp8 has 4.4 bal.
Reactions: reddington
post-15184803
Post #21,549 of 21,843
Gayron
Russia
Russia
Andromeda is quite bright, thus I think you should get a warmer amp for it, which is Amp9.
post-15184823
Post #21,551 of 21,843
Snowball0906
Malaysia
Malaysia
post-15186974
Post #21,553 of 21,843
lightning3777
Malaysia
Malaysia
hi folks, I have DX200 and using it for about 3 years now. Starting this week, my DX200 suddenly switch off when playing music. The battery indicate it is at 91% before it suddenly switch off. So i switch on the player and the battery indicator shows 89%. this problem occurs every 2/3 minutes everytime I switch on the player. Could u advice me what to do with it? FYI, Im on the latest firmware which is V1.07 and using AMP9, AMP 7 & AMP4
post-15187055
Post #21,554 of 21,843
ropie
If it is still the original battery you are using, then I recommend replacing the battery
You can buy it from Ibasso for €15 (excluding shipping)
Replacing is easy do it yourself
I had the same problem, and now it is working perfect again
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
