Womaz
Yeah, I was in the same situation with the Tidal app. It works perfectly on my IOS devices, and other android DAPs. It was slow as molasses on the DX200. I never figured out why because I switched to UAPP and never looked back. Unfortunately UAPP does have a learning curve, but the developer is one of the most helpful and engaged guys out there. It also does sound significantly better than Tidal and has options for EQ, etc. It is also really cheap. Just a thought if you can’t figure things out with Tidal.
Yes I think I will have to look at this as tidal is the only reason I have the DAP. I don’t even keep my own music on it anymore .
I have no idea what UAPP involves, but I presume it would replace what I did with the lurker upgrade. I will investigate . My other alternative is a move back to A&K as they appear to have some new DAPs out that work with tidal without the need to side load, however I do enjoy my Dx200 so loathe to change this. Thanks for your posts , very helpful
